Posted August 17, 200420 yr comment_91589 I have a 1971 240z. When I accelerate to 60 mph my car starts to vibrate the faster I go the more it vibrates. Has anyone every had this problem, if so, what did you do.. Link to comment https://www.classiczcars.com/forums/topic/12907-car-vibrates/ Share on other sites More sharing options...
August 17, 200420 yr comment_91591 Balance the tires/wheelsRebuild suspension (ball joints, inner & outer tierod ends, wheel bearings) Link to comment https://www.classiczcars.com/forums/topic/12907-car-vibrates/#findComment-91591 Share on other sites More sharing options...
August 17, 200420 yr Author comment_91594 I have new ball joints, wheel bearings, tierods ends and stuts. Link to comment https://www.classiczcars.com/forums/topic/12907-car-vibrates/#findComment-91594 Share on other sites More sharing options...
August 17, 200420 yr comment_91595 Sounds like Carl hit it on the head. Re-balance wheels. Weight fell off my car once, shook like a washing machine on spin cycle! Chris Link to comment https://www.classiczcars.com/forums/topic/12907-car-vibrates/#findComment-91595 Share on other sites More sharing options...
August 17, 200420 yr comment_91596 I have new ball joints, wheel bearings, tierods ends and stuts.Then I would first check for a Tire/Wheel imbalance.Could also be a rotted steering coupler. was that replaced or inspected for damage? 30 yr old rubber deteriorates.Did you have Nissan OEM suspension parts installed? If not, you wouldn't be the first one to discover that "some" aftermarket suspension parts (tierods, ball joints, etc) are not worth the powder it would take to blow them to hell and back. Link to comment https://www.classiczcars.com/forums/topic/12907-car-vibrates/#findComment-91596 Share on other sites More sharing options...
August 17, 200420 yr comment_91597 u-joint!- Jeff Link to comment https://www.classiczcars.com/forums/topic/12907-car-vibrates/#findComment-91597 Share on other sites More sharing options...
August 17, 200420 yr comment_91598 u-joint!- Jeffcoud be, but usually u-joints act up before you reach 60 mph. Still, worth checking out. Link to comment https://www.classiczcars.com/forums/topic/12907-car-vibrates/#findComment-91598 Share on other sites More sharing options...
August 17, 200420 yr comment_91599 Need more info. Did this start all of a sudden , or after some work or new tires? have you had the front tires off for any reason .? A couple of things to check. Jack up the front of the car and spin the tires and watch for out of round , or a flat spot. Have you had to stop quickly locking up the tires ? While off the ground , grasp the tire front and rear and try to wiggle the tire from side to side looking for any play , do the same grasping from top to bottom . I know you said all is new but check any way. Again while off the ground loosen the lugg nuts untill the wheel is loose then re tighten while off the ground . Is there play in the steering , worn or loose any thing ? Link to comment https://www.classiczcars.com/forums/topic/12907-car-vibrates/#findComment-91599 Share on other sites More sharing options...
August 17, 200420 yr comment_91603 Look for nots on the tires as well.Check your front axel boots. Link to comment https://www.classiczcars.com/forums/topic/12907-car-vibrates/#findComment-91603 Share on other sites More sharing options...
August 18, 200420 yr comment_91638 My vote is wheel balance. Take it to a tire store for a proper balance. Do not take it to Wal-mart! Those Mickey-Mouse mechanics couldn't find the underside of a car if it ran them over. Link to comment https://www.classiczcars.com/forums/topic/12907-car-vibrates/#findComment-91638 Share on other sites More sharing options...
August 18, 200420 yr comment_91744 I had a similar experience and it turned out that the steel belts had shifted inside the tire ,which had plenty of tread. Link to comment https://www.classiczcars.com/forums/topic/12907-car-vibrates/#findComment-91744 Share on other sites More sharing options...
August 19, 200420 yr Author comment_91772 I've checked all of the suggestions even had my tires re-balanced.. I guess will take to Hurst Imports he the best in this area..any more ideals.... Link to comment https://www.classiczcars.com/forums/topic/12907-car-vibrates/#findComment-91772 Share on other sites More sharing options...
