Posted April 7, 200223 yr comment_5122 I havent seen one before, certainly not on my Z. The Q is in my post on the photo gallery: its a Q about a part on the top of Paul Dinnels car. http://www.240z.org/photopost/index.php?photo=198 i'm pretty curious as to what it is and why i havent got one!!Then again I dont have trible Minukis either. THANKS! Link to comment https://www.classiczcars.com/forums/topic/1293-guys-whats-this/ Share on other sites More sharing options...
April 7, 200223 yr comment_5124 Are you talking about the air filter he has on the valve cover??Instead of running the vent line back to the block he just put a short section of hose and used a filter on that. Link to comment https://www.classiczcars.com/forums/topic/1293-guys-whats-this/#findComment-5124 Share on other sites More sharing options...
April 7, 200223 yr Author comment_5125 Thanks 2many, thats exactly what I was asking about.Any advantage of doing this?? Link to comment https://www.classiczcars.com/forums/topic/1293-guys-whats-this/#findComment-5125 Share on other sites More sharing options...
April 7, 200223 yr comment_5126 Well, when you take off all the smog equipment you have no place to run the vent on the valve cover. On a stock engine it is run back to the intake, to "recycle" the gases from the crankcase. Some people have been known to use a filter like this on the rear diff. vent and some even put a filter on the transmission vent too. The main advantage to put a little air filter like this is that not only will it keep any sludge from being pumped out of the crankcase it will also keep any dirt or dust particles from entering the engine and contaminating the oil. If I'm not mistaken, during deccelaration you can pull a bit of vaccum in the crankcase so it is possible to pull contaminates into the valve cover. Besides, they look cool. Link to comment https://www.classiczcars.com/forums/topic/1293-guys-whats-this/#findComment-5126 Share on other sites More sharing options...
April 8, 200223 yr comment_5137 Ok, is it difficult to install??? What about special fittings? My car does not have the smog pump (air pump), so can I do it also??? Link to comment https://www.classiczcars.com/forums/topic/1293-guys-whats-this/#findComment-5137 Share on other sites More sharing options...
April 8, 200223 yr comment_5145 The standard engine has the PCV pipe going to the air filter box from the valve cover. Because the car in the photo has non standard carbs they would of have had the choice of putting a filter on the valve cover, or running the pipe to the new carbs, which would be more tricky to do.The PVC system is designed to suck the nasty gasses out of the crankcase, through the engine where they are burnt, so they aren't so nasty when they come out of the exhaust.Mr C. Link to comment https://www.classiczcars.com/forums/topic/1293-guys-whats-this/#findComment-5145 Share on other sites More sharing options...
April 8, 200223 yr Author comment_5152 Ok thanks for the info. So I gather that its use is to do with smog issues and that if you had EFI, like I do, it cant be done or would be totally pointless to do. THANKS! Link to comment https://www.classiczcars.com/forums/topic/1293-guys-whats-this/#findComment-5152 Share on other sites More sharing options...
April 9, 200223 yr comment_5186 It's definitely a smog issue. I don't know anything about the interaction between EFI and the smog junk, (I have a '71 240) but I suppose it COULD be done. However, if you have to keep the smog junk, it would be as you surmised - pointless.JIM DOZIER Link to comment https://www.classiczcars.com/forums/topic/1293-guys-whats-this/#findComment-5186 Share on other sites More sharing options...
