Source for clutch LSD's
drunkenmaster
I havent seen that on SAU, but wouldnt it be just as easy to fit a mechanical centre into an OEM open diff?
Ideally I would just like a complete unit to save on any potential mismatch problems.
I have got in touch with a few wreckers and there seems to be not a lot around.
Anyone got a detailed listing fo what cars they are found in?
Import R31?
Import/Local Z31?
Ripper: AFAIK the R32 onwards and the s13 on wards use the short nose R200 which isn't directly interchangable. HR31 is definitely ok, not sure about the Z31s. Z32s are definitely out being an R230.
Oh, and long and short nose R200 centers are not directly interchangable either.
No HR31's should be fine, definetely not aussie ones, they use live rear axle. Yes Z31s should work, although they have a strange LSD, wouldn't recommend them. I have seen a few z32's with R200, and as far as I know, all of them used them (could be wrong). the R200 is a standard Nissan part, it hardly changed over the years, and was used in all Nissan sports cars from early to mid 80's to present.
The HR31 is the japanese spec R31, which had the R200. I'm 99.9% sure all the Z32s had the R230, however I have also seen a few with a R200 swapped in. I assume this is due to a larger choice of LSD centers.
From what I've been told, it's some of the bolt spacing on the LSD centers that differs between the long and short nose R200s.
