Posted April 8, 200223 yr comment_5155 Just bought a 240z last week and am in the process of making it a bit more drivable. The shifter is ALL over the palce. Is there way to tighten it up? TIAAlex Link to comment https://www.classiczcars.com/forums/topic/1299-shifter-slop-fix/ Share on other sites More sharing options...
April 8, 200223 yr comment_5156 You must have a 70 or 71.There are bushing you can replace,but that tranny is known for your problem.I replaced every piece rubber and metal in the shifter of a 70 I restored once.It was still hard to tell neutral from in gear.On the bright side welcome to the world of Z cars.You can easily upgrade to a better tranny! Have Fun!! Daniel Link to comment https://www.classiczcars.com/forums/topic/1299-shifter-slop-fix/#findComment-5156 Share on other sites More sharing options...
April 8, 200223 yr Author comment_5157 So I could yank a 5spd out of a later 260 or 280 and replace it? How tough is that? I love the car otherwise. Having a street legal go-kart is a blast. Link to comment https://www.classiczcars.com/forums/topic/1299-shifter-slop-fix/#findComment-5157 Share on other sites More sharing options...
April 8, 200223 yr comment_5158 Check out the web links on this site. Z garage is good. It is a very common swap to goto a 5 speed box. You might have to cut where the shifter hole is though...anyway, I'm no expert....check out those sites.Zed not Zee Link to comment https://www.classiczcars.com/forums/topic/1299-shifter-slop-fix/#findComment-5158 Share on other sites More sharing options...
April 8, 200223 yr comment_5159 What year is your car? Link to comment https://www.classiczcars.com/forums/topic/1299-shifter-slop-fix/#findComment-5159 Share on other sites More sharing options...
April 8, 200223 yr Author comment_5163 A year older than me. 1971 Link to comment https://www.classiczcars.com/forums/topic/1299-shifter-slop-fix/#findComment-5163 Share on other sites More sharing options...
April 8, 200223 yr comment_5165 Well, if it is the original trans you have the A type transmission. Unfortunately the A type has the worst shifter, it is a very simple swap to put the later B type model 4 speed in or you could swap to a later 5 speed. Of course you could just re-build the shifter on the A type, not sure the complete list of parts you need as I have taken out the A type from my car and am going to replace it with the B type. The internal shift rail on the B type gives a much better feel to the shifter. Not as much slop, and it is a bit stronger than the A type. Link to comment https://www.classiczcars.com/forums/topic/1299-shifter-slop-fix/#findComment-5165 Share on other sites More sharing options...
April 9, 200223 yr comment_5206 SirJester,You can put in a later 4 or 5 spd. The problem is the hole where the shifter comes through the tunnel is located dirfferently on the A type trans that came in a 70. Youwill have to cut out some of the tunnel, and I think trim some of the console too. That is what keeps me from putting a 5spd in my 70. It boils down to how original do you want to keep your car.The website that was mentioned has a lot of good info. Check it out.Marty Link to comment https://www.classiczcars.com/forums/topic/1299-shifter-slop-fix/#findComment-5206 Share on other sites More sharing options...
