Posted August 27, 200420 yr comment_92959 I have a 1972 240Z, am running a stock exhaustsystem on this. It's time for a replacement ! Idon't want a custom exhaust , I want a simple stock.I have been everywhere, Midas, Monroe, NAPA,Autozone, to mention a few. It's always the same reply " no longer available " .Does anyone know of any suppliers that stillcary them ? :sick: Link to comment https://www.classiczcars.com/forums/topic/13020-parts/ Share on other sites More sharing options...
August 27, 200420 yr comment_92962 If you are able to install the exhaust, you could look at ones from Motorsport Auto. They are under the performance areas.This one should really close to being stock.http://www.zcarparts.com/store/merchant.mvc?Screen=PROD&Product_Code=15-6302&Category_Code=PEC07 Link to comment https://www.classiczcars.com/forums/topic/13020-parts/#findComment-92962 Share on other sites More sharing options...
August 27, 200420 yr comment_92963 You might want to check our archives before deciding on a pre-made system from MSA. Many people have reported fitment problems with those systems.The system linked above doesn't have provision for the factory pre-muffler, so it doesn't really come close to a stock OEM system.A local quality muffler shop should be able to bend up a simple exhaust system using your stock one at a guide/pattern. Link to comment https://www.classiczcars.com/forums/topic/13020-parts/#findComment-92963 Share on other sites More sharing options...
August 27, 200420 yr comment_92965 I've got that system from MSA. Fitment wasn't too bad, I did have some problems getting it away from the diff. One of the bends actually sits on the edge of my diff. I also had some problems with the muffler, but that's only because I have some body damage right there.If you're looking for stock, this system is not even close to it. It's a 2 1/2" piping that removes the pre-muffler and straightens out the whole system some. It's great for performance and gives it a nice sound, but it's not close to stock.I think Victoria Brittish used to carry a stock replacement exhaust system that was from the exhause flange on the manifold to the rear muffler. You might want to check there.If you're anywhere near Los Angeles and you want to meet up I can show you my setup, although I'm running through the MSA headers also.Scott Link to comment https://www.classiczcars.com/forums/topic/13020-parts/#findComment-92965 Share on other sites More sharing options...
August 27, 200420 yr comment_92967 Your best bet is to go back to midas or another muffler shop and to have them replace your stock exhaust with the same diameter pipe and a quality muffler. Get the aluminized steel it will last a lot longer. Link to comment https://www.classiczcars.com/forums/topic/13020-parts/#findComment-92967 Share on other sites More sharing options...
August 27, 200420 yr comment_92975 Have you tried VictoriaBritish they carry stock arrangements page 110 catalog # z.42 Link to comment https://www.classiczcars.com/forums/topic/13020-parts/#findComment-92975 Share on other sites More sharing options...
August 27, 200420 yr Author comment_92978 Thanks EdMidas told me he didn't have bipe benders to bend pipe that small, but he could bend larger pipe and and flange them down to fit. The real problem was the muffler, he couldn't find one small enough to fit in the compartment where the stock muffler fits.I found a muffler at Advance Auto Parts ( available on line only ) $26.99. Looks likemy only option at this point. I have ordered a Victoria British catalog, today, but can,t find anything online ! Link to comment https://www.classiczcars.com/forums/topic/13020-parts/#findComment-92978 Share on other sites More sharing options...
August 28, 200420 yr comment_93002 John, You should tell us where you are. I'm sure Almost everyone here knows where a good pipe bender is that could make you a stock set up. If your in Los Angeles, I'm tripping over 2 usable stock systems - They were WAY too quiet for my sports car! Hate to throw them out. Link to comment https://www.classiczcars.com/forums/topic/13020-parts/#findComment-93002 Share on other sites More sharing options...
August 28, 200420 yr Author comment_93024 Victor :Thank you for your reply ! I am located in upstate NY a little town called Amsterdam,and I would hate to see you just throw them out to. Again thank you !John Link to comment https://www.classiczcars.com/forums/topic/13020-parts/#findComment-93024 Share on other sites More sharing options...
