Posted August 29, 200420 yr comment_93165 I am having trouble finding the switch on the a pillar that lights the dome light when the door is opened . That and the spark plug looms. If anyone has any I would appreciate it. Thanks. Link to comment https://www.classiczcars.com/forums/topic/13051-light-switch/ Share on other sites More sharing options...
August 29, 200420 yr comment_93168 I need both switches also . If you find a sorce please share the information. What spark plug looms are you referring to , the seperaters that hold the plug wires in place? If it is the latter , I found a few sets at the bone yard from the newer Zs and from Maxamas. Also they are a good place to look for the hood levelers. Gary Link to comment https://www.classiczcars.com/forums/topic/13051-light-switch/#findComment-93168 Share on other sites More sharing options...
August 30, 200420 yr comment_93234 what year and model???? :stupid: Link to comment https://www.classiczcars.com/forums/topic/13051-light-switch/#findComment-93234 Share on other sites More sharing options...
August 30, 200420 yr comment_93239 Regarding the plug lead separator or clips, I don't know the exact tem, you can fing them inthe U.S. regularly on ebay. As for the light switches, I'm sure if you did a little research they would be a generic switch from any number of Datsun models from the same year (possibly even non Datsun)(I may be mistaken, it wouldn't be the first time.) Link to comment https://www.classiczcars.com/forums/topic/13051-light-switch/#findComment-93239 Share on other sites More sharing options...
August 30, 200420 yr comment_93280 rumshak, I have a '73 , both of the door switches are shot. Gary Link to comment https://www.classiczcars.com/forums/topic/13051-light-switch/#findComment-93280 Share on other sites More sharing options...
September 3, 200420 yr comment_93679 On the door switches, if I remember correctly, you can pull the switch out, open it up, and clean the contacts. A simple but not necessarily long-term fix, is to rotate the shaft so that the contacts come together in a different way. For me on my 73, that was enough on one door to make them work nearly every time.For the spark plug loom, check either MSA or VB. Can't remember which one I bought from, but it was cheaper than most of the ebay solutions. Just add it to an order of other stuff so you don't get killed on shipping. Link to comment https://www.classiczcars.com/forums/topic/13051-light-switch/#findComment-93679 Share on other sites More sharing options...
September 3, 200420 yr comment_93685 Here is a new one $21.99.http://cybersanford.net/NEWPARTS!.html Link to comment https://www.classiczcars.com/forums/topic/13051-light-switch/#findComment-93685 Share on other sites More sharing options...
September 3, 200420 yr Author comment_93713 I'll pull a switch out next week and hit the nissan dealer . If I find any matches I'll post it. Link to comment https://www.classiczcars.com/forums/topic/13051-light-switch/#findComment-93713 Share on other sites More sharing options...
September 4, 200420 yr comment_93745 My switches are toast . there is not any thing left . Link to comment https://www.classiczcars.com/forums/topic/13051-light-switch/#findComment-93745 Share on other sites More sharing options...
September 4, 200420 yr comment_93764 I'm parting out a 75 280Z that I found on eBay last week. (Do a search on "75 280Z partscar") I'll take a look at the door switches on this one today and see what they look like. webdawg1 Link to comment https://www.classiczcars.com/forums/topic/13051-light-switch/#findComment-93764 Share on other sites More sharing options...
September 4, 200420 yr Author comment_93803 I'm sure they would fit , the wires are just soldered on. If you want to sell the let me know. thanks. Link to comment https://www.classiczcars.com/forums/topic/13051-light-switch/#findComment-93803 Share on other sites More sharing options...
September 4, 200420 yr comment_93832 door switches are toast. @^&!*+# Damn rust monster strikes again...Sorry!!webdawg1 Link to comment https://www.classiczcars.com/forums/topic/13051-light-switch/#findComment-93832 Share on other sites More sharing options...
