Connections will likely be different, but you should be able to swap connectors or rewire to work in your 240Z.
There are a few people in the US that take 280Z "Quartz" clock mechanisms and install them in 240Z clock housings, retaining the 240Z faceplate and connectors. They work great.
240znz
I bought a quartz 260z clock, and swapped in the front face, and front housing. Connectors are different but I just soldered on the leads from a 240z clock. I had to make up a small bracket to attach the newer clock into the 240z dash as the 260z one attaches differently. I couldn't use the rear housing from a 240z clock because the quartz mechanism is so much bigger.
I did this myself after trying zclocks.com, but I assume he doesn't ship outside the US as he never replied to my enquiry.
hope it helps
Andrew
