Posted September 3, 200420 yr comment_93641 I was thinking of what some options are in intercoolers. I heard of GReaddy, HKS, and Blitz are pretty good. Would any of these fit a 240Z frame. Trying to get some opinions and an estimate of how much one will cost.Thanks Link to comment https://www.classiczcars.com/forums/topic/13100-intercooler-choices/ Share on other sites More sharing options...
September 3, 200420 yr comment_93643 There are a couple of guys here who will be able to help, but the majority will be at www.hybridz.org Link to comment https://www.classiczcars.com/forums/topic/13100-intercooler-choices/#findComment-93643 Share on other sites More sharing options...
September 3, 200420 yr Author comment_93645 Thanks for nothing :mad: Link to comment https://www.classiczcars.com/forums/topic/13100-intercooler-choices/#findComment-93645 Share on other sites More sharing options...
September 3, 200420 yr comment_93671 I have heard that the Supra Turbo intercooler can work, and the Isuzu NPR truck intercooler will work. Those are cheaper alternatives than getting the three expensive name brands you listed. The Isuzu truck might be harder to find if you have no salvage yards for truck parts in your area. Chris Link to comment https://www.classiczcars.com/forums/topic/13100-intercooler-choices/#findComment-93671 Share on other sites More sharing options...
September 3, 200420 yr comment_93711 240Zdragon72 said: Thanks for nothing :mad:Nothing? That link is probably the best resource you'll ever find for your project. If you already know about it, sorry, but I assumed you didn't because you posted it here. Geez Link to comment https://www.classiczcars.com/forums/topic/13100-intercooler-choices/#findComment-93711 Share on other sites More sharing options...
September 4, 200420 yr Author comment_93747 No, its not you, I hate going to that site B/C you have to search first and that could take hours. Sorry if I came on too harsh. Just needed a quick direction to go. Link to comment https://www.classiczcars.com/forums/topic/13100-intercooler-choices/#findComment-93747 Share on other sites More sharing options...
September 4, 200420 yr comment_93770 Isuzu NPR, Mitsubishi Conquest (or GM equivalent), Ford Power Stroke, Audi, Ford Probe, and more. I am going to use several smaller cores on the same plenum, with a HO fan pulling air through.AutoSpeed did an article on flow rates through about 15 yard pulls to find out what was the best. I can probably find and email that article if you are interested.Will Link to comment https://www.classiczcars.com/forums/topic/13100-intercooler-choices/#findComment-93770 Share on other sites More sharing options...
September 7, 200420 yr comment_94244 If you were to state what you power expectations are, you might get a better answer...The Conquest/Starion intercooler is not that great. NPR is better. Link to comment https://www.classiczcars.com/forums/topic/13100-intercooler-choices/#findComment-94244 Share on other sites More sharing options...
September 8, 200420 yr comment_94295 I gave some options earlier, here are what they have been going for on Ebay.NPR $225-325Starion/Conquest $50-150 Power Stroke $250Audi $40-80Probe $50-90Volvo $50-70Mitsubishi 1st gen $35-50Will Link to comment https://www.classiczcars.com/forums/topic/13100-intercooler-choices/#findComment-94295 Share on other sites More sharing options...
September 8, 200420 yr Author comment_94364 Thanks hls30.com I will be searching e-bay when I get home! To others : I am buying what I think to be a "stock" '83 280ZX Turbo engine. I will be fitting it into my '72 240Z. I was just wanting some ideas as to what has worked in the past. (Blitz, HKS, and GReddy don't sell any for this engine. And MSA is way too costly!) :tapemouth Thanks Link to comment https://www.classiczcars.com/forums/topic/13100-intercooler-choices/#findComment-94364 Share on other sites More sharing options...
September 8, 200420 yr comment_94371 i can get you a 28x9.5x2.5 with 2,5" inlet/outlet which flows 510hp for $350 plus shipping which isnt more than $20 and those measurements are from inlet to outlet Link to comment https://www.classiczcars.com/forums/topic/13100-intercooler-choices/#findComment-94371 Share on other sites More sharing options...
September 8, 200420 yr comment_94398 240zdragon72,I am in the midst of the same build-straightening out the chassis first. I am doing some unusual things in terms of engine management, and intercooling-pm me if you want to swap notes, ideas, parts... WillAV240ZYou probably know this, and were trying to make a quick blurb to get a sale, but others don't, so here it is.An intercooler does not flow or make horsepower, it allows you to tune an engine management system to make more horsepower by cooling the intake air of a compressed air intake system. An intercooler flows, and hopefully cools, intake air. Making the air more dense through compression by a turbocharger adds heat. Making the air even more dense by cooling it, means more can get into a cylinder. More air in a cylinder means you must add more gas, in the right ratio. More gas and more air, in the right ratio, means more horsepower. Once you have more cool dense air and gas in a cylinder, the timing of the spark can be adjusted, hopefully to make more horsepower. The variables of intake temperature, fuel delivery, air delivery, and ignition timing all have an optimum range. An intercooler allows you to have some control over the one of the two variables that a normally aspirated car does not-intake temperature. Balancing all four variables properly in a healthy engine will result in operation somewhere between maximum fuel efficiency and maximum horse power-depending on your tuning. Two more important questions to answer are: 1)What is the internal pressure drop across meaningful flow rates through the intercooler (usually expressed as a curve graph) Do the math to change cfm to rpm-it sounds worse thanit is-and make sure that the sweet spot of your turbo is within the efficient portion of the graph. If it isn't the intercooler in question is not your best choice.2)What is its BTU dump in through time and volume of air both through and across the ic(usually 2 graphs superimposed on each other-where the two curves cross is the upper limit of efficiency-check the numbers from the answer to the first question, and the cfm of your radiator fan(if you know it), and make sure they fit)Most Manufacturers don't and won't publish either of these because their sales people don't want us to know what their engineers know.Will Link to comment https://www.classiczcars.com/forums/topic/13100-intercooler-choices/#findComment-94398 Share on other sites More sharing options...
