ricksaia Posted September 3, 2004 Share #1 Posted September 3, 2004 Hello all, my 1983 f54 block is all set. What I want to know is with my P90 head. I had the head milled .050, with the stock block (non-turbo), what would be my compression ratio? Is an easy answer possible? Please let me know. Thank you, Rick. Link to comment Share on other sites More sharing options...
Phred Posted September 3, 2004 Share #2 Posted September 3, 2004 If you can take your head to a race engine shop and get it CC'd, I can tell you what your Compression will be. I will also need to know if you are using a stock head gasket, and what the deck height is, and if those are flat top pistons.Phred Link to comment Share on other sites More sharing options...
Ed Posted September 4, 2004 Share #3 Posted September 4, 2004 Phred, I want to take you up on this offer of figuring out the compression ratio. I just finished cc'ing my head and these are the #'s I came up with:#1- 38.8, #2- 38.6, #3- 39.2, #4- 39.4, #5- 38.6, #6- 38.2The block is a '81 F54 with the stock flat top pistons. And I'm using a Felpro head gasket. Also I have a .020 head gasket shim by Felpro but I'm not sure if I'm going to use it. I guess it all depends on what my compression ratio comes out to.Thanks Link to comment Share on other sites More sharing options...
Phred Posted September 5, 2004 Share #4 Posted September 5, 2004 Hi Ed,You're only missing one critical measurement which I will make an educated guess on. If it varies much from my assumtion, I can easily refigure it into the formula.First, figure the known actual figures:Bore/Stroke:3.39 X 3.11 = 2759.95 cc'sHead Gasket:3.49 X .047 = 7.37 cc'sHead Gasket Shim:3.49 X .020 = 3.14 cc'sCombustion Chamber volume, (Ave.) 38.8 cc'sNow, the unknown guess:Deck height: -.010 (area above the piston @ TDC) =1.48 cc'sNext we just add them up to find total compressed volume:7.37 + 3.14 + 38.8 + 1.48 = 50.79 cc'sNow divide the displacement of one cly. by compressed volume, Then add 1 (a math thing to arrive at a ratio) and you have 9.06:1 compressionIf you delete the shim vol. of 3.14 cc's you come up with a total vol. of 47.65 and a compression of 10.65:1Class is over for today, remember to play nice with the other Z kids.Professor Phred Link to comment Share on other sites More sharing options...
ricksaia Posted September 5, 2004 Author Share #5 Posted September 5, 2004 The head was at the machine shop for 2 months, I would rather not take it back. To find out the CC's might take another month. The block is a flat top piston F54 and the head gasket is from felpro. Is it possible to find out a ballpark figure? Let me know, thanks, Rick. Link to comment Share on other sites More sharing options...
Ed Posted September 5, 2004 Share #6 Posted September 5, 2004 Thanks Professor. Link to comment Share on other sites More sharing options...
Phred Posted September 6, 2004 Share #7 Posted September 6, 2004 Rick,As you can see in the figures for Ed, a small change can make a big difference in compression. There are so many variables with you head, a guess here could be downright dangerous. .050 off you head? How much before? sunk valves? new Valves? You can't guess here, as a wrong guess could mean a blown engine. Phred Link to comment Share on other sites More sharing options...
ricksaia Posted September 6, 2004 Author Share #8 Posted September 6, 2004 Thank you. I knew my question was a little vague. With all the reading and research, I am going to assume (I know) a 9.5 CR. I hope I am right. Thanks again. Rick. Link to comment Share on other sites More sharing options...
Ed Posted September 6, 2004 Share #9 Posted September 6, 2004 Rick, PM your address and I will send you the piece of plexiglass and the syringe that I used to calculate the cc's on my head. It's easy to do and will take you less than an hour. Link to comment Share on other sites More sharing options...
