Tacho suddebly quit?
TomoHawk
The last time I drove my 280Z, the tacho worked, but last week I was cleaning the intake, then covered the car for a few days of rain and now the tacho quit working!
I thought maybe I broke a connection or something. Does the sensor wire go from the coil to the tacho, thought the firewall by the battery? I was trying to trace the wire, but it's not easy with the covering. :hurt:
BTW, where's the ballast resistor on a 78 280Z (F.I.)?
thx
If you ever find out what the problem was, let us know as I have the same problem in the 77.
My guess has been a dry joint or similar in the tach itself as a broken wire to the tacho would dis-able the ignition circuit.
I've lived without a tach for 3 years now, so I can wait a little longer...
MOM
