I do believe that the 77 was the last of the externally regulated cars. My 78 is internally regulated and I recall that when I replaced it the application said 78-83. If you look at the back of your alternator, that is the one you removed, you can see the voltage regulator through the slots. It's held in place by two 12mm nuts spaced 2" apart. If you don't see that then it's externally regulated. Vicky and Scott (ZRush) have a 77. Maybe they can help here.
  • 3 weeks later...
