I'm sorry, I got too involved with the rear because that was a harder one to swap. Yes, the shock mounting holes are too close together. I mounted the brackets on the bumper loosely first, then put the bumper with the brackets attached on the car. I then marked where the bolt holes should go and drilled holes in the correct place. It really isn't a hard swap once you get the old shock absorbers off.
Joe
Joe
