Posted September 15, 200420 yr comment_95215 :stupid: Hey, my speedometer on my 1975 280Z does nothing except light up.... any ideas? Link to comment https://www.classiczcars.com/forums/topic/13254-speedo-help/ Share on other sites More sharing options...
September 15, 200420 yr comment_95234 First guess, Broken speedo cable. To test unscrew it from the tranny and turn it while someone watches the speedo for needle movement. Link to comment https://www.classiczcars.com/forums/topic/13254-speedo-help/#findComment-95234 Share on other sites More sharing options...
September 17, 200420 yr Author comment_95529 First guess, Broken speedo cable. To test unscrew it from the tranny and turn it while someone watches the speedo for needle movement.ok i couldnt look at the tranny part...no lift yet.i did however discover that the knurled knob was undone at the back of the speedo. I reconnected that--still no luck. also noticed that the "trip odometer" cable was just floating in fid-air not doing anything...must figure out where that goes. Link to comment https://www.classiczcars.com/forums/topic/13254-speedo-help/#findComment-95529 Share on other sites More sharing options...
September 17, 200420 yr comment_95568 What do you know about where your car came from?Will Link to comment https://www.classiczcars.com/forums/topic/13254-speedo-help/#findComment-95568 Share on other sites More sharing options...
September 18, 200420 yr Author comment_95573 hmm, i know it was built in yokohama! but i think you mean , where in teh states. I belive its from northern california... Link to comment https://www.classiczcars.com/forums/topic/13254-speedo-help/#findComment-95573 Share on other sites More sharing options...
