Gotta question
MrMarcDude
(78 280z) Ok, im in the process of rebuilding my engine. I just got 500 bux that i can spend on parts. So im getting main, and rod bearings, rings, and some other small stuff. I was wondering which of these two am i supposed to get for my mains? http://shop.nissanpartstore.com/?make=NI&year=1978 Thanks a bunch EDIT: Go to the main bearings section under engine mechanical. There is STD, and 0.25mm (0.010") Which one is for me?
STD is for use on an engine where the crankshaft bearing surfaces DO NOT require machine work to remove grooves or other distortion.
0.25mm (0.010") is for use on an engine where the crankshaft bearing surfaces HAVE BEEN machined 0.25mm smaller in diameter than normal (stock)
Until you know the condition of your crankshaft (examined and measured by a knowledgable automotive machine shop) it is impossible to know which bearings you should purchase to properly rebuild your engine.
