anyone know where to get door hinges at? my darn door wont close!!!!!
Junk yard or someone with a parts car. There are a few other 'companies' that may have them like Danny's Datsuns, Zed Findings, etc.
If you need the passenger side hinges I have a set from my '73 parts car; the driver side sold months ago.
well the door hinge that is mounted on body is fine. it is the peice on the door that doesnt latch on to that hinge. maybe i just need to tear it down or something :(
when i lift up on the door handle, it doesnt move. i have to just pull out for the door to open.
I believe I have these parts also! :)
Before you go swapping these out or anything try cleaning and greasing yours up to see if you can get them to work. All of the grease may have dried up causing the part not to opperate any longer.
