My first post.. headlights, signals, brakelights
WandererS30
Check fusible links. Have you looked under the dash for evidence of a hacked wiring harness? How did you test fuses? Did you remove them all and test them? I'd replace them anyway, What's $3?
Looking for used parts? Check the Tech Articles forum. Thers's a thread with a list of USED parts sellers there.
Well, I am not trying to seem lazy, but It has been a little chilly the last couple of nights...... but the overall consesus about the car is that it's rather clean and unmolested.... So I doubt that the harness has been hacked up under the dash, but I do hope to get into it tonight. Thanks for all the help. :classic:
Thanks for the lead also on the sellers, I have been browsing all the different forums looking for different parts. I can definately say this seem to be the best of all of the forums I have found.
BTW, where are the fusable links located at?
I would suggest tht you get a 12 volt buzzer from Radio shack. I glued mine to tongue depressor/craft stick and added wires with clips for the power & ground.
that way you can test for power without having to look, like the brake lights or headlights.
  • Who's Online   1 Member, 0 Anonymous, 458 Guests (See full list)
