this post reminds me. the container where we fill the wiper fluid, it leaks from the bottom and even if its filled up, it does spray anymore. i am away from my car so i cant look and see what the problem is but i think there is a broken motor. anyone know or have what im talking about?
Marc:
First step is to see what is leaking. tubing, motor (doubtful), or the bottle itself.
If motor is bad, they are only available with the washer bottle (cost = over $100) you can buy a Trico brand Washer pump (model #11-601) which will fit perfect, but you would need to change one wire on the pump from a male spade to a female spade connector (at least that is what is needed for a 240Z) in order to connect it to the car wiring.
FYI all -
I'm getting a wiper motor sent to me from 280Zone (thanks Robert). I have to hold off on the master vac due to unexpected shortage in car fun funds (girlfriends b-day for cripe's sake).
Cheers,
Shawn
thanks to all who replied!
