75 280 wiper motor, brake booster
seemyz
this post reminds me. the container where we fill the wiper fluid, it leaks from the bottom and even if its filled up, it does spray anymore. i am away from my car so i cant look and see what the problem is but i think there is a broken motor. anyone know or have what im talking about?
Marc:
First step is to see what is leaking. tubing, motor (doubtful), or the bottle itself.
If motor is bad, they are only available with the washer bottle (cost = over $100) you can buy a Trico brand Washer pump (model #11-601) which will fit perfect, but you would need to change one wire on the pump from a male spade to a female spade connector (at least that is what is needed for a 240Z) in order to connect it to the car wiring.
  • Who's Online   2 Members, 0 Anonymous, 512 Guests (See full list)
