October 21, 200420 yr comment_98880 Dave, The '78 2+2 I bought was vandalizad by chopping up the harness, if the plugs from it will help, I will send them to you.PS, just about setup for photographing/taping/testing the harness install-just gotta find some better lights-I vwant to film at night to show the fifferences in the headlight brightness-hopefully.Will Link to comment https://www.classiczcars.com/forums/topic/13455-headlight-relay-upgrade-harnesss-for-sale/?&page=7#findComment-98880 Share on other sites More sharing options...
October 21, 200420 yr comment_98889 I will be interested in a 280 harness as well Link to comment https://www.classiczcars.com/forums/topic/13455-headlight-relay-upgrade-harnesss-for-sale/?&page=7#findComment-98889 Share on other sites More sharing options...
October 21, 200420 yr Author comment_98917 Good research Andrew,The headlights, tail lights, sidemarkers and front parking lights ALL run thru that 3rd fuse down on the right, thats why it is so prone to melting. Using my new harness reduces the amperage thru that fuse by at least 18 amps.Which also puts less strain on the fuses, fusebox, and the switches and headlight associated wires. I've been told that the harness should actually stop ALL melting and over heating in the fusebox due to the reduction of amperage that would normally flow thru it.Send me your tired, your poor, your un-used 280 plugs. If I can't find a supplier, This ain't gonna happen. But I'll figure it out.Dave. Link to comment https://www.classiczcars.com/forums/topic/13455-headlight-relay-upgrade-harnesss-for-sale/?&page=7#findComment-98917 Share on other sites More sharing options...
October 21, 200420 yr comment_98918 I'll round up what I have,Will Link to comment https://www.classiczcars.com/forums/topic/13455-headlight-relay-upgrade-harnesss-for-sale/?&page=7#findComment-98918 Share on other sites More sharing options...
October 21, 200420 yr comment_98932 Zs-ondabrain said: Good research Andrew,The headlights, tail lights, sidemarkers and front parking lights ALL run thru that 3rd fuse down on the right, thats why it is so prone to melting. Using my new harness reduces the amperage thru that fuse by at least 18 amps.Which also puts less strain on the fuses, fusebox, and the switches and headlight associated wires...........................Dave.Hey Dave:Are you saying that the headlights are powered through all of the top 3 fuses on the right side of the fusebox? BOTH Headlamps through 3rd from Top on RightandLeft Headlamp through Top RightRight Headlamp through 2nd from Top on RightI tried to follow the schematic I have, but I get lost in the fusebox area. it's clear as mud to me. Link to comment https://www.classiczcars.com/forums/topic/13455-headlight-relay-upgrade-harnesss-for-sale/?&page=7#findComment-98932 Share on other sites More sharing options...
October 21, 200420 yr comment_98961 The tail lights, marker lights, and the front parking are all on a seperate 20A fuse. The interior lighting are on their own seperate 10A fuse. And the headlights are on two seperate 10A fuses.So no they are not together in any way. I have no clue why the tail lights would melt the fusebox.This is for USA and Canada 240's only. Link to comment https://www.classiczcars.com/forums/topic/13455-headlight-relay-upgrade-harnesss-for-sale/?&page=7#findComment-98961 Share on other sites More sharing options...
October 22, 200420 yr Author comment_99007 Sorry Carl, Steve is right. My brain has the consistancy of pudding this week. But I do have a suggestion for all of you who are experiencing hot 3rd fuse down on the right. I converted my sidemarkers to L.E.D. and my tail lights and front parking and turn signal lights are now 1156 and 1157 L.E.D. bulbs. they can be spendy but I weigh the price of the fuse box and switch against the L.E.D. bulbs, and the L.E.D.s win the fight. I paid $100 for all my L.E.D. style bulbs and it WILL be worth the price I paid someday, My 3 fuses never get hot any more, My dash lights appear to be brighter and so does my dome and map light. Putting in the harness also increased the brightness of the other lights by drawing less power from the fusebox.Dave. Link to comment https://www.classiczcars.com/forums/topic/13455-headlight-relay-upgrade-harnesss-for-sale/?&page=7#findComment-99007 Share on other sites More sharing options...
October 22, 200420 yr comment_99021 Can you tell us more about your dash lights? PM me if you want. I thought of putting in l.e.d. bulbs for the gauges, thinking they would be brighter, but would like some confidence from others first. Link to comment https://www.classiczcars.com/forums/topic/13455-headlight-relay-upgrade-harnesss-for-sale/?&page=7#findComment-99021 Share on other sites More sharing options...
October 22, 200420 yr comment_99035 Yes, can you please give us more information about your LED conversion? I was thinking of doing this on my dash lights but had not thought about the tail lights or marker/signal lights. I would like some words of wisdom from someone who has been there. I'd be interested in where you got the parts, what was involved, part numbers if you have them still, etc, etc, etc.I do think that a new thread should be started for this though Zs-ondabrain so as not to take this one off topic. Link to comment https://www.classiczcars.com/forums/topic/13455-headlight-relay-upgrade-harnesss-for-sale/?&page=7#findComment-99035 Share on other sites More sharing options...
October 22, 200420 yr Author comment_99062 To all who are interested,I started a new thread on L.E.D.s in a forum called "L.E.D. solutions for dash and other lights"http://www.classiczcars.com/forums/showthread.php?postid=105036#post105036Put your 2cents worth in and we can figure this thing out.Dave. Link to comment https://www.classiczcars.com/forums/topic/13455-headlight-relay-upgrade-harnesss-for-sale/?&page=7#findComment-99062 Share on other sites More sharing options...
October 23, 200420 yr Author comment_99236 Hey Guys and Gals, I checked on a couple things this week end. I the 260Z only used one style of headlight connector, the black rubberish bullet style. The 280Z's (75' to 78') used only one other style of connector, the elongated-white three pin connector. If anyone knows of a distributor for either of those two style plugs, let me know. If you have ever seen these style plugs on ANY other make or model of car/truck/van/or S.U.V. Please contact me with the info so that I can go to the local (pull a part) junk yard, and rsearch the info.Thanks in advance for all of your help, Dave in WA. state Link to comment https://www.classiczcars.com/forums/topic/13455-headlight-relay-upgrade-harnesss-for-sale/?&page=7#findComment-99236 Share on other sites More sharing options...
October 24, 200420 yr comment_99274 Righto. Finally got around to checking out my plugs. Left hand side has a round plug* (this is 240Z style right?), and the right has no plug at all.....yet another thing on this car that has been molested by the PO. I'm quite interested still, but I'll have to hold off for a month or two as there's a major lack of fundage around here atm! *My 260Z is one of the very early ones that is a mish mash of 240 and 260 parts....so seems 240Z HL plugs are another item to add to the list! Arrrhhh! Link to comment https://www.classiczcars.com/forums/topic/13455-headlight-relay-upgrade-harnesss-for-sale/?&page=7#findComment-99274 Share on other sites More sharing options...
