Posted September 29, 200420 yr comment_96822 I want to identify this mikunis. There are for sale and want to get all kind of info.mikuni.bmp Link to comment https://www.classiczcars.com/forums/topic/13456-can-you-identify-this-mikunis/ Share on other sites More sharing options...
September 29, 200420 yr comment_96835 need a better phot that shows the details of the top jet access cover and float cover. All I can see from that blurry photo is that they are PHH's. duh! Link to comment https://www.classiczcars.com/forums/topic/13456-can-you-identify-this-mikunis/#findComment-96835 Share on other sites More sharing options...
September 29, 200420 yr Author comment_96867 The guy who's selling them told me that these numbers are stamped "N40PHH970 461"if they were phh's, what would be a good price to pay on these used ones?.What would be the perfect L-28 engine for them? Link to comment https://www.classiczcars.com/forums/topic/13456-can-you-identify-this-mikunis/#findComment-96867 Share on other sites More sharing options...
September 29, 200420 yr comment_96896 Hard to tell from the photo, but it looks like they are mounted to an original Mikuni manifold. They also have the air horns mounted -- good feature. For the carbs themselves, the number you quote indicates that they are 40mm throttle bore. A good size for low RPM street use, but you would need 44mm units to pull 7K rpm on a 2.8 without restriction (you can do it with 40's, but it will be somewhat restrictive).Clean 40's have been running about $500 with manifold on E-bay. Note that like all carbs, these must be rejetted to match engine displacement and state of tune. If not a similar engine combination, figure about $5 per jet times 3 types of jets (main, main air, pilot) times 6 throats (basically $90 per jet change). A little more expensive than a Holley! Also note that Mikuni's have been out of production for years, and service parts are a little hard to come by. Motorcycle shops can help with some jets, www.wolfcreekracing.com has been helpful as well. Link to comment https://www.classiczcars.com/forums/topic/13456-can-you-identify-this-mikunis/#findComment-96896 Share on other sites More sharing options...
October 1, 200420 yr Author comment_97104 Yes, the link also mikuni. They're selling all the car at e-bay it's a Texas 260zmikuni-closeup.BMPmikunis3.BMP Link to comment https://www.classiczcars.com/forums/topic/13456-can-you-identify-this-mikunis/#findComment-97104 Share on other sites More sharing options...
