"Injection inlet manifold for any L series Nissan 6 cyl.
Has an extra set of injectors fitted to double the fuel available. Seemed like a good idea at the time"
http://www.trademe.co.nz/structure/0001-0877-2780-2783-/auction-16407513.htm
hi
was woundering if it has been tried before,
would it be diffcult to pull off,
thanks
Looks like an OEM part with nipples added.
Problems that come to mind:
1)The supply tube does not have enough volume to feed all of those injectors throughout the powerband-talk about pressure drop!
2)The stock ECM does not have enough current to drive double its designed for load,
Good idea, but unless you can take care of the problems, and have a turbo or supercharged system it will fit on, you would probably put it back at auction after playing with it.
Will
Will
