hey everybody, my 1975 280z was having a problem where only the left turn signal worked. then, all of the sudden about a week ago, it stopped working and now the right signal works. anyone have an idea on what is going on? should i take the steering wheel off and do some cleanup and hope that works? cuz im not so confident in my electrical skills so any input is appreciated
~Jerrod
https://www.classiczcars.com/forums/topic/13499-turn-siganls-ahhh/
Jerrod, listen to Jason. He's a pro at this by now ROFLLOL . jk
no kidd'n, huh!! and also check to make sure that everything is plugged in to the right plugs.... BEFORE you spend $200+ on diagnostics...
  • 2 months later...
Got the Z back from the body shop and the left turn signal doesn't flash. The right works fine. I noticed that the left signal arrow lights up but doesn't flash. Right arrow lights up & flashes. Ideas?
"Seem" OK? What does that mean? Have you moved the one that doesn't light to another location and confirmed that it CAN light? You can't judge by looks.
Other possible causes for a "functional" bulb not "functioning" can be corrosion, bad or missing grounds, broken wires, or bad switch.
Both VB & MSA list replacement T/S switches for $99-$117. Has anybody here ordered one of these? How did work out? I think mine is pretty worn & mushy in addition to the left turn signal not working.
