Email logins are now active ×
Steering wheel vibration
nuteman
For all of you new guys that may not be mechanically inclined, BUY A FACTORY SERVICE MANUAL !!!!!! The early Z's are not that hard to repair and/or maintain but you must have at your side a FACTORY SERVICE MANUAL. The factory manual will tell you almost everything you need to know about your Z. They are the best guide to repairing your Z that you will ever get. Trust me ! I'm and old Motor head that has always bought the manual first. Good luck and buy a box of band aids.
cremmenga, Check out this site. They have a lot of god info on it. Tech Tips
And, yes, just start takin everything off that needs to and replace when done. There are a couple of tricks to getting some of the parts off/out. If you have difficulty with any specific parts, drop me an email.
Joe
Try tightening your front wheel spindle nuts a little bit. My 71 240 had the same issue. After replacing rack bushings, coupler and rack lash adjustments without sucess, I tried it. Belive it or not that fixed the problem. Wish I would have tried that 1st, rack bushings are a pain to install!
