Posted April 13, 200222 yr comment_5469 I've seen a picture before of a z in MSA with the headlight covers painted to the color of the car..but then is there another soultion to installing a separate set of headlights anywhere on the grill or something..Does that make sense..?Ak Link to comment https://www.classiczcars.com/forums/topic/1352-while-were-on-the-subject/ Share on other sites More sharing options...
April 13, 200222 yr comment_5477 Just a sugestion, before you do a modification such as that you best check the highth requirements of he headlights and also the placement as to there visibility from the side , like when aproaching an intersection. DOT and the dept. of Motor vehicles have specifications reguarding this stuff. Just thought I would pass on info. good luck. Link to comment https://www.classiczcars.com/forums/topic/1352-while-were-on-the-subject/#findComment-5477 Share on other sites More sharing options...
