While we're on the subject..
Akir-ra
I've seen a picture before of a z in MSA with the headlight covers painted to the color of the car..but then is there another soultion to installing a separate set of headlights anywhere on the grill or something..Does that make sense..?
Ak
Just a sugestion, before you do a modification such as that you best check the highth requirements of he headlights and also the placement as to there visibility from the side , like when aproaching an intersection. DOT and the dept. of Motor vehicles have specifications reguarding this stuff. Just thought I would pass on info. good luck.
