Posted October 5, 200420 yr comment_97381 How do you adjust a 280Z rear wheel toe? Link to comment https://www.classiczcars.com/forums/topic/13525-rearend-alignment/ Share on other sites More sharing options...
October 5, 200420 yr comment_97383 You don't, unless you fork out the $$$ for adjustable rear transverse links. Take a look at your rear suspension on your 280Z.......you will see there is no means of adjustment. Link to comment https://www.classiczcars.com/forums/topic/13525-rearend-alignment/#findComment-97383 Share on other sites More sharing options...
October 5, 200420 yr comment_97385 A rear tire out of alignment could be blown strut, no? What about camber adjustment, doesn't that correct toe in and out. That's if you have adjustable struts I'm guessing. Anyone have a picture of a transverse link? I'd like to see that. Vicky Link to comment https://www.classiczcars.com/forums/topic/13525-rearend-alignment/#findComment-97385 Share on other sites More sharing options...
October 5, 200420 yr comment_97391 On a stock 240/260/280Z there are no alignment adjustments on the rear suspension.No CamberNo CasterNo Toe Link to comment https://www.classiczcars.com/forums/topic/13525-rearend-alignment/#findComment-97391 Share on other sites More sharing options...
October 5, 200420 yr comment_97397 Vicky, what have you been smoking my dear? Link to comment https://www.classiczcars.com/forums/topic/13525-rearend-alignment/#findComment-97397 Share on other sites More sharing options...
October 5, 200420 yr comment_97407 First you have to be sure that there isn't something wrong with your rear end that was caused by an accident. If one of your wheels is "off" then you could have a damaged control arm or something else. There are no adjustments that can be made. There is an aftermarket alternative. To adjust rear end toe in you can use adjustable control arm bushings made by G-machine. Victoria British sells them Part # 88-701. I always thought the section between the control arms was called the transverse link? Link to comment https://www.classiczcars.com/forums/topic/13525-rearend-alignment/#findComment-97407 Share on other sites More sharing options...
October 6, 200420 yr comment_97487 There is an aftermarket alternative. To adjust rear end toe in you can use adjustable control arm bushings made by G-machine. My husbands car has the adjustable (G-Machine) rear toe. He explained the whole thing to me this morning, the bushings, how he can adjust, etc.Sorry Tom, to sound as if I've been smoking something. I'm just trying to lean all I can about the stock version, preferably my 72 240Z. I have nothing to compare the '72 240Z to since the '77 280Z is so heavily modified.(Thanks for the transverse link picture Carl)Vicky Link to comment https://www.classiczcars.com/forums/topic/13525-rearend-alignment/#findComment-97487 Share on other sites More sharing options...
