I have a '73 and I think that your cars battery area is vary similar to mine. I removed the tray with a spot weld cutter . However a drill will work to drill through partially , and remove the tray , cut away the offending rusted metal and have sheet metal welded back in. At the same time you can have any holes that went through from the tray removal filled. I bolted the tray back in after treating all the bare metal and painting with POR inside and out. This way I was able to keep por inbetween the tray and the inner fender. Or you can of course have the tray welded in place. Gary
