Mike, they do look good. This is an option I should explore. If you don't mind me asking, what is cost range? There are several good shops here, however I am not aware of cost and value parameters.
Another thing, I noticed the weatherstrip on you doors is not as thick as the replacement rubber I got from MSA. Did you replace or is your weatherstrip original?
thanks,
Keith
