Email logins are now active ×
replacing brake lines.. GRRRR
WandererS30
I'll go with Carl's recommendations for Classic Tube as well as Inline Tube. Also check out www.fedhillusa.com
Some other advise; Make sure the new fitting is an exact replacement - the extended necks and thread shoulders make a difference. Double flaring is a specification for safety purposes - you have to double flare. Chamfer the tube inside and out with a file before you flare the end and you get less splitting.
Thanks for the new link, Chris!
