I was able to replace 1 vent hose with shop vac hose but can't find 2" hose for the ac which are either cracked or missing. Tried plummbing supply and big box. It's amazing what else you can find when all I wanted to do was see where the green and white wire went! Any ideas for hoses welcome. thanks
https://www.classiczcars.com/forums/topic/13764-under-dash-hoses/
I've got all the under dash vent hoses on my parts car. If you could be a little more specific as to which one you need I can pull it for you. From memory:
There is one from the blower to the heater core box thingy, this one is square. Then from the heater core there are five, two lower one's that go to the outside round vents on the dash. Two that go up to the defogger. And one that goes out the front to the center console. Not too sure about this though with out looking.
Let me know which one you need.
Ed
If you're not looking for stock items, go to an after market auto A/C supplier.
I replaced my entire heat/ac unit with a setup from Southern Air. Don't have their web page but Street Rodder Mag would have it.
Good Luck.
Evidentally, the original hoses are still available. On my 78, I had my heater core, and all the valves, water and vent hoses, clamps, etc. replaced last year by a buddy of mine at his shop. He used all OEM stuff exc. the core itself. I have also found good vent hoses at the junkyard to use as backup.
Didn't even think about air cond shop (not many around). But will try that and oem route . I could not find them online and figured no go. And thanks for the offer Ed but I don't want to take somthing you can use if it's still available.
