Posted October 26, 200420 yr comment_99567 Hi,I'm looking for the heater hose fitting that threads into the rear carb manifold. It's the inlet for the carb preheater line, near the back of the head/block on a '72 Z.thanx!joel Link to comment https://www.classiczcars.com/forums/topic/13789-carb-preheater-inlet-fitting/ Share on other sites More sharing options...
October 26, 200420 yr comment_99573 Good Luck. My experience has been that after 30 years, they will not come out of a manifold without getting destroyed. I've been trying to get one for a spare manifold for 2 years now and I've broken 4 in attempts to remove them from JY cars. IF Nissan still sells them, they are way too pricey for me. Link to comment https://www.classiczcars.com/forums/topic/13789-carb-preheater-inlet-fitting/#findComment-99573 Share on other sites More sharing options...
October 26, 200420 yr Author comment_99574 That's the problem I've had, and of course the part is NLA from Nissan. I was able to get the broken part out using Kroil and a screw extractor. Has anyone tried to find a suitable tubing fitting? As far as I can tell it's a 3/8" JPT fitting (which should be the same as a 3/8" BPT fitting), but I can't find a U.S. supplier for them. Haven't had time to see if there is similar fitting from a British manifold setup, since they also used a preheater.joel Link to comment https://www.classiczcars.com/forums/topic/13789-carb-preheater-inlet-fitting/#findComment-99574 Share on other sites More sharing options...
October 26, 200420 yr comment_99579 Keep in mind that the Datsun OEM part is a valve that shuts off water flow at a pre-determined water tempurature so that the carbs and manifold are only heated until the engine warms up. Allowing water flow at all times will likely result in issues with the carburetors not operating well. Many of us (even those with a valve) disconnect or otherwise disable the manifold/carb preheat feature if we don't have really cold weather to deal with. Link to comment https://www.classiczcars.com/forums/topic/13789-carb-preheater-inlet-fitting/#findComment-99579 Share on other sites More sharing options...
October 26, 200420 yr Author comment_99583 Understood, but here in Colorado I've noticed that ever since disconnecting the circuit, cold performance is not very good. Possibly due to true carb icing. Alsp, the various British makes that had preheaters didn't have a thermovalve (that I can find reference to). I'll keep trying to find an original -- there has to be one somewhere!thanx,joel Link to comment https://www.classiczcars.com/forums/topic/13789-carb-preheater-inlet-fitting/#findComment-99583 Share on other sites More sharing options...
October 26, 200420 yr comment_99603 It seem that based on Carl's history with removal. I would suggest a machine shop. Perhaps they can drill it out and rethread to an available part or make one to fit the datsun thread.. I cant see that being very expensive. Link to comment https://www.classiczcars.com/forums/topic/13789-carb-preheater-inlet-fitting/#findComment-99603 Share on other sites More sharing options...
October 27, 200420 yr comment_99649 If the valve has snapped off like in this picture, you can drill out or EZ-Out the threads that are stuck in the manifold. I'm going to try dressing up what is left of the threads on the valve and re install it. It won't matter much to me if it isn't water tight since I block off the other end of the valve with a bolt and silicone so there won't be any flow.From what 2ManyZs told us, the valve shuts off water flow at 80 degrees F, so just using a nipple and allowing flow at all times would seem to be a sure fire recipe for carb problems (once the water is up to 180 to 190 degrees F)Here are a few threads:http://www.classiczcars.com/forums/showthread.php?t=14245http://www.classiczcars.com/forums/showthread.php?t=13973&highlight=80+degrees Link to comment https://www.classiczcars.com/forums/topic/13789-carb-preheater-inlet-fitting/#findComment-99649 Share on other sites More sharing options...
October 27, 200420 yr Author comment_99731 well, push comes to shove, I can drill/tap for NPT and add a valve, not unlike my '64 Land Rover's heater shutoff valve...God Save the Queen.joel Link to comment https://www.classiczcars.com/forums/topic/13789-carb-preheater-inlet-fitting/#findComment-99731 Share on other sites More sharing options...
