Hi,
For my '70 240Z...
I used an impact to remove the bolt that holds on the AC & Crank pulley. I'm assuming I use the impact wrench to put it back on too. Am I correct? I just don't want to damage anything. :nervous:
Thanks,
Steve
https://www.classiczcars.com/forums/topic/13843-ac-pulley-impact-wrench/
hey,I would rather find out the foot pounds that the bolt has to be tightened and then do it with a torgue wrench and afriend to help hold the pulley and crank still while you tighten it up......thump
I second that. Proper torque is preferred.
