November 2, 200420 yr comment_100411 thanks for your time, i'd love a copy as well.mtdripo@yahoo.comdan Link to comment https://www.classiczcars.com/forums/topic/13853-electronic-distributor-install-instructions/?&page=2#findComment-100411 Share on other sites More sharing options...
November 2, 200420 yr comment_100416 I'd like one too gavindoolan@optusnet.com.au if you like I'll host it at viczcar.com and anyone can download it then Link to comment https://www.classiczcars.com/forums/topic/13853-electronic-distributor-install-instructions/?&page=2#findComment-100416 Share on other sites More sharing options...
November 2, 200420 yr comment_100418 Those instructions would be a good thing to put in the archives or donload section.they are well done, and full of info.Thanks for sending them out,Will Link to comment https://www.classiczcars.com/forums/topic/13853-electronic-distributor-install-instructions/?&page=2#findComment-100418 Share on other sites More sharing options...
November 2, 200420 yr Author comment_100430 Hey Will , I sent Mike a copy as well, and offered that suggestion, Gavin that also sounds like a great ideal, Good luck guys Link to comment https://www.classiczcars.com/forums/topic/13853-electronic-distributor-install-instructions/?&page=2#findComment-100430 Share on other sites More sharing options...
November 3, 200420 yr comment_100534 http://www.viczcar.com/Technical/Dizzy/elecdiz240z.pdf just incase it's not uploaded to Classiczcars.com here it is courtesy of VicZcar enjoy! Link to comment https://www.classiczcars.com/forums/topic/13853-electronic-distributor-install-instructions/?&page=2#findComment-100534 Share on other sites More sharing options...
November 18, 200420 yr comment_102379 i would love to have a copy to troubleshoot my '70 tach wired to a zx distributor. Thanks!!emccallum@emeraldis.com Link to comment https://www.classiczcars.com/forums/topic/13853-electronic-distributor-install-instructions/?&page=2#findComment-102379 Share on other sites More sharing options...
November 21, 200420 yr comment_102624 http://www.pertronix.com/home.htmhttp://www.carshopinc.com/product_info.php/products_id/80/1761Check our these sites. At the Pertronix site check out the ignition kit link. My local Z shop is installing these into OEM 240Z distributors, while maintaining the original exterior appearance (i.e., you don't even know the car has electronic igniton). I'm told none have come back with problems. Link to comment https://www.classiczcars.com/forums/topic/13853-electronic-distributor-install-instructions/?&page=2#findComment-102624 Share on other sites More sharing options...
November 21, 200420 yr comment_102625 My local Z shop is installing these into OEM 240Z distributors, while maintaining the original exterior appearance (i.e., you don't even know the car has electronic igniton).Except for the electric wires going to the ignition that wouldn't otherwise be there at all. Link to comment https://www.classiczcars.com/forums/topic/13853-electronic-distributor-install-instructions/?&page=2#findComment-102625 Share on other sites More sharing options...
November 21, 200420 yr comment_102627 We've been doing this for years. No need to go to a shop for it to be done. http://www.classiczcars.com/forums/showthread.php?t=10538The two wires for the pertronix ignitor are easily routed along the original wires and hidden. Much less obvious than a Crane (POS) system, or the ZX Upgrade Dist. Link to comment https://www.classiczcars.com/forums/topic/13853-electronic-distributor-install-instructions/?&page=2#findComment-102627 Share on other sites More sharing options...
November 21, 200420 yr comment_102628 texasz, don't be a party-pooper. Link to comment https://www.classiczcars.com/forums/topic/13853-electronic-distributor-install-instructions/?&page=2#findComment-102628 Share on other sites More sharing options...
November 21, 200420 yr comment_102697 texasz, don't be a party-pooper. Sorry just pointing out what will be noticed by any Z fan at a show or when pix of the car are shown around. Link to comment https://www.classiczcars.com/forums/topic/13853-electronic-distributor-install-instructions/?&page=2#findComment-102697 Share on other sites More sharing options...
November 22, 200420 yr comment_102764 IF ITS STILL AVAILABLE I WOULD APPRECIATE A COPY SENT TO ME.THYLAND@SATX.RR.COMTHANK YOU IN ADVANCE Link to comment https://www.classiczcars.com/forums/topic/13853-electronic-distributor-install-instructions/?&page=2#findComment-102764 Share on other sites More sharing options...
