Email logins are now active ×
L28 Problems - Will not rev over 3.5k - Possible Air Flow Meter Prob
SugarFreeGum
Ok,
Car was running well a few months ago.
1981 280zx N/A (n42 head) EFI
Current problem.
10-20% throttle engine runs fine. When throttle is half way the car chuggs and strugles, when its pressed to the floor it takes off and runs fine up to 3500 - 4000rpm, Once it gets to about 4k it struggles to get any higher.
Engine idle is good usually around 800-1000rpm (althought i have seen it idle high at 1200rpm)
All injectors & electrical connectors have been checked and are fine
Injector seals, rubbers plasitc caps have all been replaced.
Fuel Filter is clean
Fuel system has been cleaned
Rebuilt distributor
new spark plugs & leads
My mechanic seems to think it may have something to do with the air flow meter? As if its not getting enough air, or getting to much prehaps?
I've taken the cap of the AFM and reved the engine, and the AFM seems to be opening & closing ok.
Any suggestions would be much appreciated.
Have you checked the hoses for holes and/or cracks? Try feeling around both of the large corrogated hoses that are attached to the air flow meter and the throttle body. Also, there should be a smaller hose, about 1" in diameter, under the intake manifold that runs from the manifold forward to (I believe) the throttle body. This smaller hose probably has a foil covering on it that makes a person think it could be a metal tube. I found a hole in this one that caused problems. I know your Z is a later model than my '75 280, but I would think the intake system hoses would be basically the same (no need to change what works well!)
Hope this helps,
Rob
I havn't checked any of the sensors as i'm not too sure how. I've searched and read for many hours through many posts but still unsure.
My mechanical knowledge is very limited.
Where is the throttle position tester and how can i test it?
thanks!
It's located on the side of the throttle body. It's the black box secured with two mounting screws. Remove the connector and you'll see three numbers on the throttle position sensor that correspond with the three terminals. Check for continuity between terminals 29 and 30. If it's good but needs to be adjusted that is kind of a hands-on thing but it's outlined in the FSM.
Ok, after playing some more, i tightened up the boot in between the AFM and TB. I just took it up to 5000rpm with no probs, it still seems to hesitate a little after. The boot had a few smal cracks but they only looked like surface cracks. I might get the boot replaced, at least it seems to be running alot better.
  • 3 years later...
