Can someone tell me what the specs are on stock springs?
ID?
OD?
Length?
The Ground Control website says that you can order Eibach springs in any spring rate you want. This might be the solution I have been looking for.
Marty
https://www.classiczcars.com/forums/topic/13907-stock-spring-sepcs/
Hey guys,
According to Haynes manual,240z front coil springs, 10.6mm for wire dia, 100.0 mm for coil dia. # of turn 10, Free lenght 373.5 mm(LH) 386.0mm (RH). Rear coil springs: wire dia. 11.4mm, coil dia 100.0mm, # of coils 10.65, free lenght 381.00mm.
260z frt; 11.5mm wire dia, 100.0mm coil dia, # of turns 10.75, free lenght 394.0mm.
Rear, for both cars; 11.4mm wire dia, 100.0mm coil dia, # of coils 10.65, free lenght 381.0mm.
Cheers, Ari
