November 18, 200420 yr comment_102287 How well does the powdercoat hold up to parts that flex? Will it flex a little or not at all? Link to comment https://www.classiczcars.com/forums/topic/13968-powder-coated-240z-suspension-finished/?&page=3#findComment-102287 Share on other sites More sharing options...
November 18, 200420 yr Author comment_102288 silver vein, that dosent look like silver vein. definately hammertone and note straight hammerWell thats whats written. It is hammertone, and has silver in it but I don't see the vein either. :stupid: Link to comment https://www.classiczcars.com/forums/topic/13968-powder-coated-240z-suspension-finished/?&page=3#findComment-102288 Share on other sites More sharing options...
November 18, 200420 yr Author comment_102290 How well does the powdercoat hold up to parts that flex? Will it flex a little or not at all?Sorry, I can't answer that yet. I don't know by how much the powder coat adds to the strength of the metal. I'm sure different metals have different results. Link to comment https://www.classiczcars.com/forums/topic/13968-powder-coated-240z-suspension-finished/?&page=3#findComment-102290 Share on other sites More sharing options...
November 18, 200420 yr comment_102403 How well does the powdercoat hold up to parts that flex? Will it flex a little or not at all?I have a panel in my office that is bent in 2 90degree angles and has no visual wear to the paint. Because powder is urathane base(mostly) it is extremely flexible. Link to comment https://www.classiczcars.com/forums/topic/13968-powder-coated-240z-suspension-finished/?&page=3#findComment-102403 Share on other sites More sharing options...
November 19, 200420 yr Author comment_102414 How well does the powder coat hold up to parts that flex? Will it flex a little or not at all?I forgot to mention this; before any of the work started, and I was being showed around his shop and some of the samples. He showed me the hooks that he hangs the parts off of. Because they have to be bare, and clean for grounding reasons I believe, he demonstrated this for me:He took a hook that was completely coated and cured with color and he bent it back and forth over and over again, using the same principle if you wanted to break a paper clip. After bending it for a while he handed it to me to touch, and I felt no heat. Also the powder coat did not crack, chip, discolor or anything. I didn't believe my eyes and hands so I had to try it myself and resulted the same, I was amazed. That was fuel to add to my fire to go through with it, which I'm glad I did. He was telling me that it costs almost as much as buying new hooks, but he sends huge batches out to get them stripped. Apparently, there are companies out there that specialize in just that. Link to comment https://www.classiczcars.com/forums/topic/13968-powder-coated-240z-suspension-finished/?&page=3#findComment-102414 Share on other sites More sharing options...
November 20, 200420 yr comment_102593 we had a molten salt stripper for a long time but due to powdercoating getting so big we didnt have enough time to court business for stripping. And theres a new company on the market that sells hooks for insanely cheap(EPSI) and we can buy like 2500 hooks for a round 20 buck, way cheaper than any stripping we have done. Link to comment https://www.classiczcars.com/forums/topic/13968-powder-coated-240z-suspension-finished/?&page=3#findComment-102593 Share on other sites More sharing options...
