I took off the steering wheel on the z I just got. It was an old aftermarket wheel, maybe like a grant gt? The large center bolt was loose, so i removed it. One of the three smaller bolts were loose and I took it off too. Now the problem, the other two smaller bolts were on there really tight, but i was able to take them off. The two bolts stripped the plate that the wheel bolts on to. The one that says "top" on it. Now I have two bolts with surrounded by metal, not a big problem, and that plate with two big freaking holes. :(
What should I do?
Help
https://www.classiczcars.com/forums/topic/14019-stripped-bolts/
That plate is the adaptor to accept the after market steering wheel . Don't hold me to this but I don't think those bolt hold the wheel on Ithink they were for the horn button that never worked(99 percent positive). Get a steering wheel puller or have a car place yank it off. The only connection to the steering is the splines.
Never mind, I have fixed the problem. The thing i am talking about, is not stock, and i dont need it because I just got an original wheel. It was like an adapter for the aftermarket steering wheel.
When posting a picture what do i put for the URL? :nervous:
Thanks
