Stock rim tire sizes
Alex 240Z
OEM Steel Wheels or Mags? If Mags, are they the correct offset?
On my car I can use 195/70 X 14 tires, or 205/60 X 14's. If I use 205/70 X 14 tires they rub the rear fenders a bit.
Your mileage may vary.
PS, you might try a search of the site. I believe that OEM steel wheels were 5" wide, but I'm not positive. It has been discussed befroe though.
I used on my 260Z after reading in Wick Humble’s book and researching the Z-Car CD-ROM, 5 – JX14 as they seemed to be the standard. The wheels should be stamped either TOPY MM/YY 4 ½ - J14 or 5 - J14. The Z-Car CD-ROM list them as 4 ½ – JX14 (P/N: 40100-E4400) or 5 – JX14 (P/N 40300-E4400). Standard tire size is 175/70HR-14 standard with 195/70HR-14 a later option but, 185/70HR-14 90Hwill work as well. The H is the speed rating
After sandblasting, paint on 240 rims had matt black face and silver on the reverse later rims not sure when were matt black faces with gloss black.
Info from Tire Rack website
Using a P195/60R15 87S tire size as an example, the 87S at the end of the size represents the tire's service description. A service description identifies the tire's load index and speed rating. Service Descriptions are required on all speed rated (except for Z-speed rated) tires manufactured since 1991.
The first two digits (87S) represent the tire's load index and are followed by a single letter (87S) identifying the tire's speed rating.
Load Index
P195/60R15 87S - The load index (87) is the tire size's assigned numerical value used to compare relative load carrying capabilities. In the case of our example the 87 identifies the tires ability to carry approximately 1,201 pounds.
The higher the tire's load index number, the greater its load carrying capacity.
89 = 1,279 pounds
88 = 1,235 pounds
87 = 1,201 pounds
86 = 1,168 pounds
85 = 1,135 pounds
Speed Rating
Beginning in 1991, the speed symbol denoting a fixed maximum speed capability of new tires must be shown only in the speed rating portion of the tire's service description, such as 225/50R16 89S. The most common tire speed rating symbols, maximum speeds and typical applications are shown below:
N 87 mph 140 km/h Temporary Spare Tires
P 93 mph 150 km/h
Q 99 mph 160 km/h Studless & Studdable Winter Tires
R 106 mph 170 km/h H.D. Light Truck Tires
S 112 mph 180 km/h Family Sedans & Vans
T 118 mph 190 km/h Family Sedans & Vans
U 124 mph 200 km/h
H 130 mph 210 km/h Sport Sedans & Coupes
V 149 mph 240 km/h Sport Sedans, Coupes & Sports Cars
Info condensed from Tire Racks website.
Jim Atkinson
1974 260Z - RLS30-020697 (01/74)
  • Who's Online   1 Member, 0 Anonymous, 478 Guests (See full list)
