Contest: Guess what this is and win!
panchovisa
Attached are two pictures of portion of my new design for racing Z's.
Describe what it is, and ALL that it does, and you will receive a set free for beta testing when I get into production.
Note the design is copyrighted and may not be reproduced without liscense.
Photos of completed and installed device will follow in two weeks, contest ends then if no correct answer.
Ok The photo is a prototype adjustable rear suspension that goes where the rear arm attaches to the strut and brake housing Adjustable for camber and toe-in. It needs to be used with a custom set of lower control arms, hub and coil-over attachement. I don't know if I got it right. I don't want one if I win. It looks like a bunch of good machine work to me. I could not figure how the shorter pin comes into play.
