well, the fancy schmancy plugs will work in your old z, but i don't really recommend spending extra money to get the expensive split fire, or platinum, or any of that crap. the old z wasn't really designed to take advantage of that, and it will not help any. i bought my z, which had platinum plugs/split fire, and it really doesn't do jack, though i'm sure it wouldn't hurt to put some in! i'd personally save myself a few bucks, and go with the classics.
https://www.classiczcars.com/forums/topic/1407-spark-plugs/#findComment-5816
Save your money on the Splitfires, I used them and saw absolutely no difference between them and just a set of NGK's. You might want to use a set of the resistor plugs so that you don't have to worry about any radio interference.
https://www.classiczcars.com/forums/topic/1407-spark-plugs/#findComment-5817
My 74 came with splitfires- they work fine, but as i say, theycame in it from the PO. My 73 I use NGK's, and they're everybit as good as the splits, IMO. I had used Champion & Autolites in the 73 before, but they seemed to foul more than they should. Jeremiah
https://www.classiczcars.com/forums/topic/1407-spark-plugs/#findComment-5840
Since i've had my Z NGK's have always been the recommended plug by Zheads. I was told that since electricity always goes through the path of least resistance only one of the split fire electrodes is used at anyone time anyway.
https://www.classiczcars.com/forums/topic/1407-spark-plugs/#findComment-5851
