Posted November 21, 200420 yr comment_102721 I just won an ebay auction for tripple weber's/manifold/linkage http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=4504249520&rd=1&sspagename=STRK%3AMEWA%3AITproblem is, I found out how uncommon these carbs are. Can someone tell me if these are worth the money i'm about to spend?? and if they would be better than the bored SU carbs I have on my car now?? Link to comment https://www.classiczcars.com/forums/topic/14075-question-regarding-tripple-weber-carbs/ Share on other sites More sharing options...
November 21, 200420 yr comment_102725 WOW. I never knew Weber made a 42 DCOE. I thought they came in 40 or 45mm. On a L24 they be fine. If your stroker, you might be better off with the 45's. I don't have my book in front of me but from memory the L28 at 6500 revs needs 44.8mm. So 45's are fine. I know you have 300more cc but you'll probably pulling less revs. Link to comment https://www.classiczcars.com/forums/topic/14075-question-regarding-tripple-weber-carbs/#findComment-102725 Share on other sites More sharing options...
November 21, 200420 yr Author comment_102726 I guess these carbs were made for the Maserati 3500 GT (3.5 litre?) Link to comment https://www.classiczcars.com/forums/topic/14075-question-regarding-tripple-weber-carbs/#findComment-102726 Share on other sites More sharing options...
November 21, 200420 yr Author comment_102727 here's a jetting table42 DCOE 8 19570.001 32 main venturi 3.5 aux venturi 135 main jet F15 emulsion tube 155 air correc 55F2 idle jet 45 pump jet closed pump bleed 200 needle valve Link to comment https://www.classiczcars.com/forums/topic/14075-question-regarding-tripple-weber-carbs/#findComment-102727 Share on other sites More sharing options...
November 21, 200420 yr Author comment_102731 I forgot I have that book "how to modify your nissan & datsun ohc engine", and there's the formula right there on page 111. Looks like a DCOE 45 is the minimum, I could even run the 48's. Crap!! well I haven't sent the money yet. I think I'd rather take the negative ebay rep, than get something that wont work for my set up. So running 3 of these DCOE 42's isn't as good as running 2 50mm SU's?? Link to comment https://www.classiczcars.com/forums/topic/14075-question-regarding-tripple-weber-carbs/#findComment-102731 Share on other sites More sharing options...
November 21, 200420 yr comment_102736 Yeap....I'd get 45's on there or even 48's if you could get some. Bet you can't get any chokes for the 42's anyway. You'd have to get them turned up and if you haven't got a lathe, then you are in for another bill. A rush of blood maybe? Link to comment https://www.classiczcars.com/forums/topic/14075-question-regarding-tripple-weber-carbs/#findComment-102736 Share on other sites More sharing options...
November 22, 200420 yr comment_102813 why cant you get rid of stuff......nevermind Link to comment https://www.classiczcars.com/forums/topic/14075-question-regarding-tripple-weber-carbs/#findComment-102813 Share on other sites More sharing options...
November 23, 200420 yr Author comment_102921 why cant you get rid of stuff......nevermindGet rid of what?? Don't have the carbs yet. Link to comment https://www.classiczcars.com/forums/topic/14075-question-regarding-tripple-weber-carbs/#findComment-102921 Share on other sites More sharing options...
November 23, 200420 yr comment_102924 Maybe the carbs in question were on Dans240Z, or he has a set.Will Link to comment https://www.classiczcars.com/forums/topic/14075-question-regarding-tripple-weber-carbs/#findComment-102924 Share on other sites More sharing options...
November 23, 200420 yr comment_102925 I dunno i see what the dilemna is but I think once you bid you've said I'm willing to buy just because you haven't researched what you need isn't the sellers fault. Maybe you guys can reach a compromise but I just think it's a little unfair possibly the seller might be able to sell them to the second highest bidder if you write him a nice email. To answer your question though you should get 48's for the stroker. Not meaning to offend btw Link to comment https://www.classiczcars.com/forums/topic/14075-question-regarding-tripple-weber-carbs/#findComment-102925 Share on other sites More sharing options...
November 23, 200420 yr comment_102927 I'm with you Gavin, as long a the description is fair and honest, the deal is done. Approaching the seller with the problem and asking for his help is the right way to go.Will Link to comment https://www.classiczcars.com/forums/topic/14075-question-regarding-tripple-weber-carbs/#findComment-102927 Share on other sites More sharing options...
November 23, 200420 yr comment_102928 I'm with you Gavin, as long a the description is fair and honest, the deal is done. Approaching the seller with the problem and asking for his help is the right way to go.I had a guy in California bid on and win an airdam. WHen I figures out shipping, he could have bought it at MSA cheeper. I let him out. and gave him good feedback for being so straight folward. Will Link to comment https://www.classiczcars.com/forums/topic/14075-question-regarding-tripple-weber-carbs/#findComment-102928 Share on other sites More sharing options...
