Hey Guys,
I have a mostly stock 75' 280Z. Last year I changed my plugs and put in splitfire plugs. Last month i took them out to see how the condition was and i noticed that they were a little fouled. I sandblasted them and put them back in, the car was still running fine. Now a month later the car is idling a little rough, so I decided to check the plugs, when I took them out they were covered in oil. I have not idea what's going on, can anyone help?
https://www.classiczcars.com/forums/topic/14093-fouled-plugs/
Hey Guys,
Is the car burning oil? If the plugs are fouled with oil then it's either coming past the rings or through the valve guides. A compression test can help you determine which is the source of the oil.
