Posted November 26, 200420 yr comment_103237 I think I've found the problem with the Z's windhield wiper motor...Working with my electric r/c race boats, I found out that one was 'slow' because the MAGNETS in the motor had gone bad because of the heat involved over time.Over time (25+years), and with the motor under a steel panel, catching rays/heat (mine is a Florida car), the old-style magnets in the windshield wiper motors, should have gone bad, or weak, which means that you can put direct power from the battery, and you're still not going to get the right speed or strength.So the problem then would be to find out if you can replace the magnets, which are probably glued in. These could be chipped out or maybe put in an oven to (burn?) off the glue. Then you'd need to get or make new magnets. I suppose you could get the materials to cast magnets (like ceramics) but then you still need to zap them to activate the part. That might need special equipment.Maybe there is somebody in this club that has contacts or experience with magnet manufacture.Thx Link to comment https://www.classiczcars.com/forums/topic/14129-fix-for-slow-wipers/ Share on other sites More sharing options...
November 26, 200420 yr comment_103239 I wonder if the '94 Accord motors discussed on hybridz ever eventuated? Link to comment https://www.classiczcars.com/forums/topic/14129-fix-for-slow-wipers/#findComment-103239 Share on other sites More sharing options...
November 26, 200420 yr comment_103251 I am going to try to move a ZX wiper drive to my '72, wiring and all-to get more powerful wipers, and the variable timing feature.Will Link to comment https://www.classiczcars.com/forums/topic/14129-fix-for-slow-wipers/#findComment-103251 Share on other sites More sharing options...
November 26, 200420 yr comment_103260 Slow wipers are more likely to be caused by the grease in the Wiper Pivots drying out and corrosion setting in and causing a bind in the mechanical part of the system. I just rebuilt my entire Wiper system this past summer using advice posted here from EScanlon and that is exactly what I found. I have lots of pictures and a Tech Article in progress to eventually post. Link to comment https://www.classiczcars.com/forums/topic/14129-fix-for-slow-wipers/#findComment-103260 Share on other sites More sharing options...
November 26, 200420 yr comment_103279 I agree with Bambikiller on the dried grease and rust , escanlon hit the nail on the head . He and I both live in the northwest and heat is not an issue up hear, not at least like in the sunbelt. And we still have the slow wyper problem . Mine were two speed . Slow and slower. I removed the whole systime and found one of the piviots was loose , the ball socket was shot. The other one was dried grease and the shafts that hold the wyper arms , one was worn badly and the rubber boots were shot. I got a systime form a '78 and used the parts to rebuild my 240 systeme and with new rubber boots , all is like new. I havent reinstalled it yet but I know it will be at least 50% better. My motor works just fine and always has even when the wypers were slow . my 2c Link to comment https://www.classiczcars.com/forums/topic/14129-fix-for-slow-wipers/#findComment-103279 Share on other sites More sharing options...
November 26, 200420 yr comment_103298 Tomo, your race boat is what my generation called slot cars.In your case the it's a slot car with a battery built in. Sure a SMALL motor. Large electrics in this case, NO. Have you ever had a bad heater fan magnet, alternator magnet, starter magnets? The magnetic field is created not existing.Good line of thought though. Link to comment https://www.classiczcars.com/forums/topic/14129-fix-for-slow-wipers/#findComment-103298 Share on other sites More sharing options...
November 27, 200420 yr comment_103303 .....The magnetic field is created not existing.....Actually Daniel, without the passive (i.e. NOT generated) magnetic force of the magnets, you couldn't get an electric motor to run.Enrique Link to comment https://www.classiczcars.com/forums/topic/14129-fix-for-slow-wipers/#findComment-103303 Share on other sites More sharing options...
November 27, 200420 yr comment_103308 ............ I havent reinstalled it yet but I know it will be at least 50% better. My motor works just fine and always has even when the wypers were slow . my 2cMy rebuilt system is installed and operating. One pivot was so dry of grease and corroded that I could only barely rotate it by hand when disassembled. I cleaned and lubed everything, replaced the felt washers and rubber pivot isolators, and pivot boots, then reinstalled it all and it works great. Wiper motion is faster than has been since I bought the car 6 years ago. Link to comment https://www.classiczcars.com/forums/topic/14129-fix-for-slow-wipers/#findComment-103308 Share on other sites More sharing options...
November 27, 200420 yr comment_103309 Darn! Enrique, I had hoped the small motor/in this case clause I posted would have excluded me from the basic electrics gotcha I offered. :stupid: You are indeed correct. Link to comment https://www.classiczcars.com/forums/topic/14129-fix-for-slow-wipers/#findComment-103309 Share on other sites More sharing options...
November 27, 200420 yr comment_103310 Darn! Enrique, I had hoped the small motor/in this case clause I posted would have excluded me from the basic electrics gotcha I offered. :stupid: You are indeed correct. No Worries! I laughed, and I hope you did too! Merry Thanks Giving Link to comment https://www.classiczcars.com/forums/topic/14129-fix-for-slow-wipers/#findComment-103310 Share on other sites More sharing options...
November 27, 200420 yr comment_103316 One other tip for increased WIPER PERFORMANCE is to polish and wax your windscreen although not a permanent fix it certain helps the wipers dissipate the water quicker and makes it easier to see in the rain. If you wax your car at least once a month like I do then it's alright if not then it's not really a big deal i guess. Carl I'll look forward to your technical article on the wiper motor rebuild although I'll probably have no need for it for a while since my current motor works quite well. Link to comment https://www.classiczcars.com/forums/topic/14129-fix-for-slow-wipers/#findComment-103316 Share on other sites More sharing options...
November 27, 200420 yr comment_103321 One other tip for increased WIPER PERFORMANCE is to polish and wax your windscreen although not a permanent fix it certain helps the wipers dissipate the water quicker and makes it easier to see in the rain.If you wax your car at least once a month like I do then it's alright if not then it's not really a big deal i guess. Carl I'll look forward to your technical article on the wiper motor rebuild although I'll probably have no need for it for a while since my current motor works quite well. Gavin, It's not going to be about the motor, rather it's going to be about rebuilding/servicing the mechanical parts (operating rods/joints, wiper pivots, etc.) The motors seem to just keep on ticking. Link to comment https://www.classiczcars.com/forums/topic/14129-fix-for-slow-wipers/#findComment-103321 Share on other sites More sharing options...
