Posted November 26, 200420 yr comment_103270 I found someone on the internet that will sell me OEM door weather-stripping for the 240Z real cheap. The Nissan part numbers they gave me were G6921-W6000 and 76921-E4101 (x2 for each door). I called the local Nissan dealership and the part numbers they gave me were 80335-N3700 for right door, and 80336-N3700 for left door. I also found a thread from this site with part numbers 76801-E4100 and 76802-E4100. Can anyone confirm any of these numbers? I would like to try the G6921-w600 & 76921-E4101s as they are very reasonably priced at $32 for each door. Just not sure if they will fit and are OEM. Thanks. Link to comment https://www.classiczcars.com/forums/topic/14130-door-weather-stripping/ Share on other sites More sharing options...
November 26, 200420 yr comment_103277 The correct P/N for 240Z door weather seals are 76802-E4100 and 76801-E4100. I have the seals in the OEM Nissan Bags right in front of me. Purchased from Courtesy Nissan in Richardson, TX. These are the exact Part Numbers specified in the Parts Microfiche CD76921-E8700 and 76920-E8700 are listed for 260Z (production date starting 8/73 G6921-w600 & 76921-E4101s do not appear in the Microfiche for 240 thru 280Z production$32 is a extemely cheap price. I would be astonished if the are OEM and correct for a 240Z. FWIW, many after market companies use what they believe are OEM part numbers for their own aftermarket parts. I'd bet a dollar the parts you were offered are Precision Replacement Parts brand seals and NOT Nissan parts.JMO Link to comment https://www.classiczcars.com/forums/topic/14130-door-weather-stripping/#findComment-103277 Share on other sites More sharing options...
November 28, 200420 yr Author comment_103444 Thanks for the information on the weather-stripping. I asked my contact to double check the part numbers before I ordered them. I also provided the numbers you gave me. Come to find out they made a mistake and their part numbers were wrong. Price went from $32 a door to $68.80 a door. Link to comment https://www.classiczcars.com/forums/topic/14130-door-weather-stripping/#findComment-103444 Share on other sites More sharing options...
November 28, 200420 yr comment_103473 Ah, Now the price sounds in the correct range for OEM Door seals. Link to comment https://www.classiczcars.com/forums/topic/14130-door-weather-stripping/#findComment-103473 Share on other sites More sharing options...
November 30, 200420 yr Author comment_103666 Looks like Courtesy Nissan out of Richardson, TX has pretty good prices.LH 76801-E4100 $57.95RH 76802-E4100 $57.95 Link to comment https://www.classiczcars.com/forums/topic/14130-door-weather-stripping/#findComment-103666 Share on other sites More sharing options...
