Lower alt bolt size!!!!
Xargon321
no the one on the bottom the long one that the alt pivots by.
I am almost positive that on my 72 240Z there are 2 bolts at the bottom (where the alt pivots). The hole DOES NOT go all the way through the Alternator mounting bracket. You use 2 bolts, one from the front and another from the rear to secure the Alt to the bracket. I don't remember the length of the bolts, but 8mm X 1.25 is correct.
  • Who's Online   1 Member, 0 Anonymous, 752 Guests (See full list)
