Posted December 4, 200420 yr comment_104149 Inspired by another thread asking about power output, Lets get this thread going as a reference to anyone asking the question "How much power can I get from my L series engine".Rules. Rule Number 1. If you have had your car on a Dyno post your power output here, Attach a image of the dyno result.Rule Number 2. List what series engine you have and any modification you have done to the engine ( eg L28 , .40 overbore, type of cam (durations ), induction, compression, exhaust) as much info as possible.Rule Number 3. Nissan L series 6 cylinders only.Rule Number 4. Dont post if you dont have a dyno reading and an image of the reading to attach. We want this to be factual readings. And dont post to say this is a dumb idea, or this is a good idea, or whatever. The only following posts should be dyno readings.So if you have had your Z car on a dyno, show us your results. Link to comment https://www.classiczcars.com/forums/topic/14212-l24-l26-l28-dyno-results/ Share on other sites More sharing options...
December 4, 200420 yr comment_104151 L28 (F54) bored to 2.9200B Flatop Pistonsbalanced and blueprinted internalsLinished Crankported and polised P90matchported to manifoldTriple weber 45 with 32mm VenturisLightened FlywheelMSD 6aFJ gearbox8.75:1 cr.318/.318 Cam (ex .012, opens@66 closes@26) (in .010, opens@26 closes@66)runs 110Kw @ wheels, 160 old school bHPHope this helps, im always on the lookout for these sorts of posts Link to comment https://www.classiczcars.com/forums/topic/14212-l24-l26-l28-dyno-results/#findComment-104151 Share on other sites More sharing options...
December 4, 200420 yr comment_104160 HP figures are already available from a number of sources. Dyno accuracy varies, weather conditions vary, not everyone really knows what has been done to their engine. Sunbelt and Rebello can tell you what various builds will net you. Link to comment https://www.classiczcars.com/forums/topic/14212-l24-l26-l28-dyno-results/#findComment-104160 Share on other sites More sharing options...
December 8, 200420 yr comment_104576 Can you tell me the email address for these figures? I am in the process of building a 280 motor and am interested their recommendations.ThanksBob M Bambikiller240 said: HP figures are already available from a number of sources. Dyno accuracy varies, weather conditions vary, not everyone really knows what has been done to their engine. Sunbelt and Rebello can tell you what various builds will net you. Link to comment https://www.classiczcars.com/forums/topic/14212-l24-l26-l28-dyno-results/#findComment-104576 Share on other sites More sharing options...
December 9, 200420 yr comment_104600 Also that the american dynos are somewhat optimistic with their outputs. Link to comment https://www.classiczcars.com/forums/topic/14212-l24-l26-l28-dyno-results/#findComment-104600 Share on other sites More sharing options...
December 9, 200420 yr comment_104628 Interesting statement Justin!!?? What inspires you to suggest that American dynos are more or less than anyone elses dyno? Maybe we just have healthier engines.....most likely not. Besides, we're jacking up Mr. Camouflage's thread. Link to comment https://www.classiczcars.com/forums/topic/14212-l24-l26-l28-dyno-results/#findComment-104628 Share on other sites More sharing options...
December 9, 200420 yr comment_104679 Dyno sheet here: http://www.classiczcars.com/photopost/showphoto.php?photo=6881&size=big&sort=1&cat=500For some reason I couldn't get the image location...Anywho,255 rwhp (on that day, anyway...)NA 3.1 liter (KA24+.5mm pistons, LD28 crank)Sunbelt ported and cammed N42 head11:1 CR45mm OER racing 3x2 carbs, 39mm venturisNismo 1 3/4" 6=>2 header, 3" exhaustThat's about it... Link to comment https://www.classiczcars.com/forums/topic/14212-l24-l26-l28-dyno-results/#findComment-104679 Share on other sites More sharing options...
December 10, 200420 yr comment_104724 That's more like it pretty similar to the motor I'll be building. Link to comment https://www.classiczcars.com/forums/topic/14212-l24-l26-l28-dyno-results/#findComment-104724 Share on other sites More sharing options...
December 10, 200420 yr comment_104726 for sure, cant wait till i find an LD crank Link to comment https://www.classiczcars.com/forums/topic/14212-l24-l26-l28-dyno-results/#findComment-104726 Share on other sites More sharing options...
December 13, 200420 yr comment_104964 Block L28 F54 block with siamesed bores, bored 3mm (3.1 L) 2.8 LD crank 89 mm pistons 240Z conrods Aluminium flywheel race type harmonic balancer flywheel, crank, harmonic balancer, pistons, rods all balanced Head Not sure - either N42 or P90 - will check when I get an opportunity Standard valves, ported 72 degree cam (mild spec) Compression 9.5 to 1 runs on premium unleaded fuel Ignition CDI Fuel system Throttle body fuel injection Wolf 3D Ver4 engine management Exhaust ? headers through to 2 1/2 inch mandrel bend exhaust 148 Kw at the wheels (198 horsepower) There are two dyno results - before and after some considerable tweaking of fuel and ignition maps. The top curves (after ) are the current power and torque curves. Link to comment https://www.classiczcars.com/forums/topic/14212-l24-l26-l28-dyno-results/#findComment-104964 Share on other sites More sharing options...
December 23, 200420 yr comment_106069 240ZX said: Interesting statement Justin!!?? What inspires you to suggest that American dynos are more or less than anyone elses dyno? Maybe we just have healthier engines.....most likely not. Besides, we're jacking up Mr. Camouflage's thread. It is relatively common knowledge that US dyno's often produce optimistic numbers. The types of Dyno's are actually different from Australian, the differences were explained to me before, can't remember though. Link to comment https://www.classiczcars.com/forums/topic/14212-l24-l26-l28-dyno-results/#findComment-106069 Share on other sites More sharing options...
December 23, 200420 yr comment_106080 Actually, I suspect that the difference isn't that U.S. dynos are "optimistic", just what they are measuring...SAE VS DIN VS BHP etc... for reference check out the following links:http://www.nsxprime.com/FAQ/Miscellaneous/TorqueHPSpeed.htmhttp://www.thepaty.plus.com/8v/top10/dyno.htmAnd I am sure there are others. Link to comment https://www.classiczcars.com/forums/topic/14212-l24-l26-l28-dyno-results/#findComment-106080 Share on other sites More sharing options...
