2+2 struts
ROOPZ
Thanks guys.
sbliake01, I will be using the original springs so that should cure that problem..right?
The wrecking yard where I bought them swears they are the same. They looked it up in their "book" Whatever that means!
Thanks again!
The tops are longer, the bottom perch is in a different position and they have more travell. they are about and inch to 1 1/2" longer that the 2 seater. If you put them on the 2 seater you will end up with the "Rally look". If you put shorter springs on them you risk bottoming out the struts and unseating the springs.
Why not rebuild the 2 seater struts? stick the 2+2's temporarily while you get the original struts fixed if you have to.
Thanks guys.
Thanks again!
I guess I should have been clearer. First of all, the book is wrong, they are not the same. When I said they'll fit I should have said that they'll bolt onto the car. Mr. Camouflage nicely clears up the rest of what I was trying to imply.
  • Who's Online   0 Members, 0 Anonymous, 529 Guests (See full list)
