Posted December 9, 200420 yr comment_104605 Getting ready to replace the door plastic liner and need recommendations. Do I go with the MSA replacement plastic or a Dynamat sheet instead?Thanks. Link to comment https://www.classiczcars.com/forums/topic/14264-door-panel-plastic-replacement/ Share on other sites More sharing options...
December 9, 200420 yr comment_104607 Either will do fine, Enrique wrote a great article for what you are getting ready to do-check the archives!Will Link to comment https://www.classiczcars.com/forums/topic/14264-door-panel-plastic-replacement/#findComment-104607 Share on other sites More sharing options...
December 9, 200420 yr comment_104608 I think the Dynamat would be too thick. I'd put that inside the door on the outside skin. In an earlier post EScanlon mentioned just using a cheap shower curtain liner for the vapor barrier between the door and the inside door panel. Link to comment https://www.classiczcars.com/forums/topic/14264-door-panel-plastic-replacement/#findComment-104608 Share on other sites More sharing options...
December 9, 200420 yr Author comment_104610 I checked the archives and I'm still not sure. Link to comment https://www.classiczcars.com/forums/topic/14264-door-panel-plastic-replacement/#findComment-104610 Share on other sites More sharing options...
December 9, 200420 yr comment_104611 I just did a search and couldn't find it either, I will try again when I have more time, and post the link if I am successful-but there are plenty of other pertinant posts that would probably be helpful-search "vapor barrier"WIll Link to comment https://www.classiczcars.com/forums/topic/14264-door-panel-plastic-replacement/#findComment-104611 Share on other sites More sharing options...
December 9, 200420 yr Author comment_104613 Thanks Will. I'll try that one. I'd like to kill two birds with one stone ie vapor barrier/sound deadening. Just not sure the Dynamat has a vapor barrier built into it. Link to comment https://www.classiczcars.com/forums/topic/14264-door-panel-plastic-replacement/#findComment-104613 Share on other sites More sharing options...
December 9, 200420 yr comment_104616 Here's the thread:http://www.classiczcars.com/forums/showthread.php?t=14058&highlight=shower+curtain Link to comment https://www.classiczcars.com/forums/topic/14264-door-panel-plastic-replacement/#findComment-104616 Share on other sites More sharing options...
December 9, 200420 yr comment_104619 Thanks Mike. Chris Link to comment https://www.classiczcars.com/forums/topic/14264-door-panel-plastic-replacement/#findComment-104619 Share on other sites More sharing options...
December 9, 200420 yr comment_104646 Thanks MikeW!The Dynomat (or equivalent) will perform as a vapor barrier because the material it is made up of will not absorb or be dissolved in water, so as long as your seams are tight, it will work.Will Link to comment https://www.classiczcars.com/forums/topic/14264-door-panel-plastic-replacement/#findComment-104646 Share on other sites More sharing options...
December 9, 200420 yr comment_104650 The main reason I went with the shower curtain behind the interior door panel was that I wanted to be able to remove and replace easily and if necessary, CHEAPLY.IMO, the Dynamat, Brown Breadk, Q-Pad, etc, would be both thicker and much more expensive to work with. Then when you cut all the holes to leave the access holes for the window and lock mechanism open, you've really reduced it's effectiveness.Granted, an application of the material directly behind the speaker (if you have your speakers installed on the door panels --- shudder--) will do a lot to reduce the noise and vibration generated in the door plenum by the speaker. However, a LOT of the noise inside the car is due to the resonance of so much undampened sheet metal all over the car. The interior of the doors, the interior of the rear quarter panels, the floor pan, the roof, the hatch skin, these are all areas that will resonate and in turn generate noise and transmit whatever noise they absorb from the outside. For that reason, I used POR all over the inside of these panels, then I put a layer of Q-Pad over the inside of the outside sheet metal. This alone made a very significant improvement in the noise inside the car. Then all I needed was a vapor barrier to keep the moisture that was bound to collect inside the doors (from the window), away from the inside of my brand new door panels.That is where the shower curtain comes in. It is durable enough that it can be removed (I used 3M General Purpose Adhesive) from the door, and can be re-glued and put back on.As far as killing two birds with one stone, I think that to get the BEST of both worlds, you would need to address each one separately as I did. But then, that's MY opinion.Enrique Link to comment https://www.classiczcars.com/forums/topic/14264-door-panel-plastic-replacement/#findComment-104650 Share on other sites More sharing options...
December 9, 200420 yr Author comment_104653 Thanks Enrique. Link to comment https://www.classiczcars.com/forums/topic/14264-door-panel-plastic-replacement/#findComment-104653 Share on other sites More sharing options...
October 9, 200915 yr comment_296990 Brilliant! Shower curtain... I went to the autobody supply store today and they had dum -dum, the black gooey stuff you stick it on with but no vapor barrier. I will get a shower curtain tomorrow... Brilliant and simple! Not to mention cheap... Link to comment https://www.classiczcars.com/forums/topic/14264-door-panel-plastic-replacement/#findComment-296990 Share on other sites More sharing options...
