Posted December 13, 200420 yr comment_104918 Attached is a picture of my rear quarter panel. I have read various discussions about tabco panels and I was wondering if I would need to use a replacement panel or if this can be fixed in an alternative manner... seeing as I am by no means, a body man, I was asking for general advice on this one... thanks guys Link to comment https://www.classiczcars.com/forums/topic/14300-rear-quarter-repair-should-i-use-tabco-part/ Share on other sites More sharing options...
December 13, 200420 yr comment_104920 Is that rust bubbles or scratches? Link to comment https://www.classiczcars.com/forums/topic/14300-rear-quarter-repair-should-i-use-tabco-part/#findComment-104920 Share on other sites More sharing options...
December 13, 200420 yr Author comment_104921 They're scratches where the paint has flipped up. Link to comment https://www.classiczcars.com/forums/topic/14300-rear-quarter-repair-should-i-use-tabco-part/#findComment-104921 Share on other sites More sharing options...
December 13, 200420 yr comment_104922 Check out my gallery pics. I had similar rust damage on the lower part of the panel below the gas door. I bought the Tabco panel and the body shop cut out the bad part and grafted in the new piece. Turned out fine. The Tabco panel only replaces from the bumper down however. Link to comment https://www.classiczcars.com/forums/topic/14300-rear-quarter-repair-should-i-use-tabco-part/#findComment-104922 Share on other sites More sharing options...
December 13, 200420 yr comment_104924 Here is the damage before. Link to comment https://www.classiczcars.com/forums/topic/14300-rear-quarter-repair-should-i-use-tabco-part/#findComment-104924 Share on other sites More sharing options...
December 13, 200420 yr comment_104925 If they are scratches and the metal underneath is solid, just have the panel repaired and repainted.Over the internet it is hard to determine the true condition of the metal, so it might be better to have it looked at by a body shop. Most of them will give you a free estimate and they will be in a better position to really know the condition of the metal. Link to comment https://www.classiczcars.com/forums/topic/14300-rear-quarter-repair-should-i-use-tabco-part/#findComment-104925 Share on other sites More sharing options...
December 13, 200420 yr Author comment_104927 Could the holes be filled and still look right? Link to comment https://www.classiczcars.com/forums/topic/14300-rear-quarter-repair-should-i-use-tabco-part/#findComment-104927 Share on other sites More sharing options...
December 13, 200420 yr comment_104929 Holes? I thought you said they were scratches. Big difference. It will depend on the condition of the metal. "Holes" can be welded closed IF the metal surrounding the "hole" is solid. If it is rusted, the rust must be cut out and replaced to effect a repair. Link to comment https://www.classiczcars.com/forums/topic/14300-rear-quarter-repair-should-i-use-tabco-part/#findComment-104929 Share on other sites More sharing options...
December 13, 200420 yr Author comment_104930 The lines are scratches, I was refering to the holes on the lower end under the bumper. Link to comment https://www.classiczcars.com/forums/topic/14300-rear-quarter-repair-should-i-use-tabco-part/#findComment-104930 Share on other sites More sharing options...
December 13, 200420 yr comment_104931 Same answer applies. Have it looked at by a body shop. There is no way to tell the condition of the metal around the holes and under the paint in that picture. Link to comment https://www.classiczcars.com/forums/topic/14300-rear-quarter-repair-should-i-use-tabco-part/#findComment-104931 Share on other sites More sharing options...
December 13, 200420 yr Author comment_104934 I appreciate the feedback guys, I will post pics as I get body work done, then I have to worry about returning her to her stock color (306, Sterling Silver) Link to comment https://www.classiczcars.com/forums/topic/14300-rear-quarter-repair-should-i-use-tabco-part/#findComment-104934 Share on other sites More sharing options...
