Posted December 14, 200420 yr comment_105149 I was checking the battery tray and I figured it would be rusted, the tray is actually not that bad, but theres rust on the wheel well and rusted through(I actually pressed on it and more broke off)... Does anyone know how expensive this would be to fix (an average estimate) I appreciate guys! Link to comment https://www.classiczcars.com/forums/topic/14327-rust-below-the-battery-tray/ Share on other sites More sharing options...
December 14, 200420 yr comment_105151 It's going to depend greatly on how much metal must be replaced. AND who does the work. Worst case senario: Fist size hole, battery tray needs to be removed, old sheetmetal cut out and new metal fabricated (replacements n/a). Then welded, smoothed and painted. I'm guessing but I'd say 20-30 hours @ lets say $60.00 an hour for labor = 1,200 - 1,800 bucks. (cheap)Best case senario: Fist size hole, You remove the battery tray with a spot weld remover or a drill, cut out rusted sheetmetal and fabricate a replacement (buy a panelbeater's bag and teardrop mallet). Weld in new metal, smooth and paint. Drill & bits = $50, Skill saw = $40, sheetmetal = $5, Panelbeater's bag & mallet = $65, Welder = $300, Grinder = $60, Paint & sandpaper = $20. Total = $540 bucks, (cheaper)Satisfaction of having done it yourself and aquired some cool tools = priceless. :classic: Link to comment https://www.classiczcars.com/forums/topic/14327-rust-below-the-battery-tray/#findComment-105151 Share on other sites More sharing options...
December 14, 200420 yr Author comment_105154 that sounds like a plan (the cheaper meathod) I do have friends that have tools and what not (including a welder). so all I would have in it would be a little help and price of materials and paint. is this somethere that could effect the drivability of my car? Link to comment https://www.classiczcars.com/forums/topic/14327-rust-below-the-battery-tray/#findComment-105154 Share on other sites More sharing options...
December 14, 200420 yr comment_105156 Check out my photo gallery. Just went though this. I ended up with a donor tray section from Roger at the www.Zbarn.com. The body shop cut it out and welded in the new piece. Turned out fine. Link to comment https://www.classiczcars.com/forums/topic/14327-rust-below-the-battery-tray/#findComment-105156 Share on other sites More sharing options...
December 14, 200420 yr comment_105157 Jared,Welcome to rust-world!! How much it is going to cost is a matter of what kind of result you are looking for. For an old man and collector like me, cost doesn't matter as I am looking for show perfection, bragging rights, and a bunch of other nonsense attributed to a pair of garage queens. I'll bet your lovely is a daily driver that you keep very clean and are very proud of. I wouldn't fret over the rust hole if that is the case. I would patch it, protect the rest of the area from further rust, and drive on. Enjoy your ride! Link to comment https://www.classiczcars.com/forums/topic/14327-rust-below-the-battery-tray/#findComment-105157 Share on other sites More sharing options...
